586,108 active members*
2,982 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > dsp controller RZNC 0501 software
Page 1 of 2 12
Results 1 to 20 of 24
    Dec 2012
    my new chinese CNC machine just arrived,
    it is controlled with a DSP-controller (RZNC 0510),
    but in the package, the software CD was missing,
    can someone who has the same DSP controller please email me a copy of the software?
    I would be very grateful,
    Ben
    Sep 2010
    14
    RZNC-0501
    I have this software if you still need it...
    GWEIEK CNC ROUTER
    the RZNC 0501 software should have some special parameter inside to compatible with your special machine.
    [email protected]
    skype:ms.leizhang www.wklaser.com
    Sep 2010
    14
    Sep 2010
    14
    New link as the other no longer works:
    www.blackcatcutters.com/RZDSP/RZDSPFileSet.zip
    Sep 2013
    43
    hello if you got that soft ware i could use a copied of it if u could ....thank u
    Sep 2013
    43
    Sep 2010
    14
    Both links work now.
    Sep 2013
    43
    rznc401 dsp controller rzncd5416/32/3/l1-4.111 zhb162 its is on a xhyz1224-1 table built in 2005 i try the links but it is not seeing it..any one have a driver for this one ,,or should i just give up an put a mach 3 set up on it
    Re: dsp controller RZNC 0501 software
    Hi masters!
    I am writing from Portugal, and im the owner of a Suda 1325 cnc.
    Unfortunatly im not able to read the usb pen with the RZNC-0501 controller
    Both my versions are:
    RZNC-D5416/3/ L7
    1.2 (HGQ692)
    20288
    Is there any update fo it?
    Do you know any reason why my controller is not receiving/reading the usb files?
    I go through the controller menu, i pick the "u disk file", apparently it tries to read (usb pen light flashes) but is not showing the files of the usb. I thought it might be from a bad usb pen, i tried with a new one, and nothing...
    I also tried to connect the controller to my PC, but i'm stalled by a "not recognized usb..." message. I am running windows 8, and not even picking the controler files manually it recognizes the controller, and therefore im not able to run nothing...
    Its strange because the controller is working well, and controls the machine.
    Any clue/suggestion?
    Oct 2014
    I have the same problem.
    What did you do to solve the problem?
    Oct 2014
    Hi Shapebuster,
    Quote Originally Posted by tomateesta View Post
    Hi Shapebuster,
    Hi there,
    Its simple, with mine the problem was the USB PEN size. It add 2GB, and the controller can only real until 1GB USB PENS with FAT32 Fornat (1024)
    Regards
    Nov 2009
    121
    I CAN READ 8 GIGAS 4 GIGAS
    ES POSIBLE OPEN HOW *.TXT
    Feb 2014
    13
    Dear sir
    please i need this pc software for RZNC 501
    Best regards
    ahmed
    Jan 2016
    4
    I have problém with Richauto A11, I need setup file for emergency situation, probably file *. PKG. Normal loading stops on "loading 32 %" Help me anybody. Thanks.
    Nov 2009
    121
    if you software is lost then used Vcarve
    Nov 2009
    121
    you need setup machine , sensors and parameters automatic DSP contol i do it
    Jan 2016
    4
    Re: Full RZ-DSP downloads.
    Thanks, I'll try it.
    Sep 2017
    please i need dsp controller RZNC 0501 software
Page 1 of 2 12
  1. Problem with DSP controller RZNC 0501
    By oncoarse in forum Commercial CNC Wood Routers
    Last Post: 01-23-2023, 01:08 AM
  2. Anyone use RZNC-0501 HBBC usb controller?
    By jeepers94 in forum Chinese Machines
    Last Post: 12-03-2017, 08:52 AM
  3. Differences between DSP RZNC-D5416 and RZNC-0501
    By KDRusty in forum Chinese Machines
    Last Post: 06-04-2014, 10:06 PM
  4. rznc dsp controller
    By radicalrescue in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-16-2013, 03:54 AM
  5. RZNC 0501 Plasma on/off
    By pyrohamish in forum Controller & Computer Solutions
    Last Post: 09-16-2013, 04:42 PM
