586,103 active members*
3,799 visitors online*
Results 1 to 1 of 1
Threaded View
    Oct 2006
    6
    4th Axis Programe
    I HAVE A SUPERMAX FANUC OM ,WITH 4TH AXIS ROTARY I WANT TO CUT A CAM OF 50MM DIA AND 20 MM LIFT BETWEEN LOW AND HIGH POINTS .ANY ONE HERE TO HELP WITH A SAMPLE PROGRAMME .I AM ENCLOSING THE PIC OF THE CAM ALSO .
    SO ANY ONE HELP WITH SOME SOFTWARE TIPS HOW TO CUT THE TOOL PATH I WANT TO USE 6MM END MILL FOR CUTTING AND 10MM BALL NOSE FOR CONTOURING .
    THANKS
    VINOD
    Sent from my GT-N7100 using Tapatalk 2
  1. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  2. NEED ATC PROGRAME FOR CINCINNATI
    By m.amir in forum Cincinnati CNC
    Last Post: 11-28-2013, 08:08 PM
  3. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
  4. Emco compact 5 programe problem.
    By sparkymike in forum EMCO Lathe
    Last Post: 05-05-2010, 05:41 PM
  5. arcs in threading programe
    By bala955 in forum Surfcam
    Last Post: 02-17-2010, 06:34 PM
