586,493 active members*
1,220 visitors online*
    Oct 2012
    torch control in mach3
    I made a oxy fuel cutting machine using stepper motor and Mach3 .I am having a problem with torch on/off and pierce delay. Generally mach3 is programmed,,, first the torch gets on and then the pierce delay timer start. Whereas I want it to work vice versa. As I am using the mach3 plasma set for oxy fuel cutting, so for a pierce the metal should be preheated and then the torch should be switched on. I mean I made the machine in a way the ignition of the torch is manual. And oxygen pressure valve (which is required for cutting) is connected to mach3.
    How do I configure it.?
    Mar 2009
    924
    I think you need to have a P code in front of the M code that turns on the cut valve. Something like this:
    P30 (pre heat delay)
    M03 (signal to cut valve on)
    P01 (pierce delay)
    Maybe someone who has more cam experience than me will jump in....
    WSS
    www.metaltechus.com
    Jul 2005
    2415
    Quote Originally Posted by WSS View Post
    P01 (pierce delay)
    WSS
    Close:
    G04 P## (## is in seconds)
    M03
    G04 P1 (pierce delay)
    codes that a good POST processor in a CAM program should put in for you
  1. using a relay to activate a plasma torch (mach3)
    By Delanoman in forum Mach Plasma / Laser
    Last Post: 08-26-2015, 12:33 AM
  2. post processor for mach3 plasma m03 torch on
    By dj_pigs in forum BobCad-Cam
    Last Post: 12-04-2014, 03:22 AM
  3. Turning torch on with Mach3
    By Silverback94 in forum Machines running Mach Software
    Last Post: 02-10-2012, 09:08 PM
  4. Multi plasma torch with thc/mach3
    By DanOSB in forum Waterjet General Topics
    Last Post: 08-22-2010, 09:38 PM
