586,075 active members*
4,127 visitors online*
    75
    Profile set up
    Can two profiles be set up, One for mm and one for inches and them not interfere with each other.
    Milton
    Yes.
    Jun 2007
    3757
    As Gerry says, YES.
    Use the loader, and clone your profile giving it a sensible name.
    Now change the settings after loading with the new profile, and exit Mach3 (easiest way to ensure the new setup is saved)
    Use the loader to start mach3 and select the profile you want.
    You can also create desktop Shortcuts that point to the different profiles.
    Just set the Target in the shortcut to C:\Mach3\Mach3.exe /p profilename where your profile is stored in profilename.xml
    Jun 2007
    3757
    With desktop shortcuts you can assign hot keys.
    Ctrl-alt-I for imperial.
    Ctrl-alt-M for metric.
    That's for people, like me, who use the mouse as little as possible.
  1. SX3 Profile
    By harvienielsen in forum Syil Products
    Last Post: 01-15-2011, 03:55 PM
  2. Z Profile
    By sqatch in forum Dolphin CAD/CAM
    Last Post: 01-08-2009, 06:31 AM
  3. 3D profile in NC.
    By scrapper400 in forum G-Code Programing
    Last Post: 12-02-2008, 03:27 PM
  4. Y Profile in Z
    By skipper_52 in forum Wood Lathes / Mills
    Last Post: 05-16-2008, 08:52 PM
  5. Help with profile
    By TPPJR in forum OneCNC
    Last Post: 12-28-2005, 06:22 AM
