586,036 active members*
3,490 visitors online*
Results 1 to 5 of 5
    Jan 2012
    19
    Annoying WinCNC problem
    Has anyone had an issue when openning WinCNC that you need to press the Insert key on your keyboard before you start typing or else characters become deleted as you type?
    Anyone know how to fix it?
    Jun 2007
    3757
    May have nothing to do with the problem but make sure windows 'sticky keys' is off or you might have some strange keyboard filtering software running, or is it just WinCNC?
    Try another keyboard?
    Sep 2006
    24
    I use a bluetooth keyboard so I can carry it closer to my CNC table when needed. There is always a momentary delay when I first start typing on it, especially if I don't move the cursor to the "command box" before typing.
    My first move however after opening WinCNC is to use the on-screen buttons, not to type in characters -- meaning after opening software, I would next power on my controller box, then test axis connectivity by jogging a small increment. I usually move X an inch in each direction and often Y & Z too as a precaution before homing my machine by typing in the G28 command.
    Do you still have that annoyance if you use an on screen button before the keyboard? I have a brief phone call scheduled with WinCNC (tech) this week, I could ask for you.
    Sep 2013
    6
    I have the same problem with my WinCNC and the insert key. It started when we upgraded to Windows 8. I called WinCNC tech help and they said it is because something changed in the Windows programming and they didn't have a fix for it yet. I noticed an even more annoying problem, if you open WinCNC hit the insert key all is fine, then you jump to another window to look at a drawing or email or whatever, the insert key turns off again!!! Of course you don't see this right away, till you've screwed up a bunch. So I installed a little program called CapsUnlock it will disable the insert key but it is overridible, unfortunately it locks out the capslock key so it doesn't automaticlly turn on when you open WinCNC. But all you need to do is hit Shift + Caps lock when you bootup to turn on the capslock key and you can open and close programs and different windows all day and not have and problem and NO overwriting!
    Jun 2007
    3757
    Downgrade to win7. What did you gain, other than trouble?
    Windows is not a Real Time Operating System
    repeat after me..
    and read on.. why it is (not) so.
    Time
  1. Annoying problem with parts created in SolidWorks
    By Andre' B in forum Solidworks
    Last Post: 10-23-2009, 10:35 PM
  2. WinCNC Problem?
    By Absolute Steve in forum G-Code Programing
    Last Post: 04-17-2009, 11:17 PM
  3. wincnc problem need help!!!!! Please...
    By dsgnkrft in forum WinCnc
    Last Post: 12-19-2007, 01:18 AM
  4. Annoying problem when starting VCarve Pro
    By ccsparky in forum Vectric
    Last Post: 05-08-2007, 01:22 PM
  5. annoying problem
    By castguy2003 in forum Mastercam
    Last Post: 03-23-2004, 09:54 PM
