586,250 active members*
3,277 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Tons of used thk linear guide rails and bearings
Results 1 to 13 of 13
    Nov 2011
    83
    Hi, i recently purchased a ton of new and used thk linear guide rails and bearings, 15mm and 30mm from 6" to 72" I will be using some of them for my cnc router build but i will have probably 150 (yes 150 of them)guide rails with a pair of bearings each left over, these are used but have been cleaned and checked, sticky or sloppy bearings were trashed. Is anybody interested in some of these in trade for some cool wood or some cnc router work? Maybe some cool name plaques for my daughter and 2 neices? Im sure this is probably the wrong section of the forum to post this but im trying to get to the small time diy at home cnc router audience
    Oct 2012
    179
    Need twin rail/cars for my z axis. 24 oal/12 stroke. Mail quote to [email protected]
    Mar 2008
    12
    Smile
    Hello Jimmy,I am definitely interested in a set of 30mm rails for all three axes of a planned cnc machine. I need
    2 @ 72"
    2@32"
    2@ 24"
    these sizes are not absolute,on the smaller lenghts I could go longer or shorter and I understand these rails can be but joined together to make two short rails into one longer rail,so there are a lot of different possible configurations. Of course I also will need 12 bearings for the six rails.thank you.
    [email protected]
    Apr 2005
    438
    sent you PM
    Nov 2011
    83
    Heres a picture of some of the rails i have, sorry for the crappy pictures, my basement is rather dark. I have rails with and without bearings.
    prices
    $15ea. 15mm rail 32" long
    $12ea. 15mm rail 23" long
    $10ft-30mm rail
    $60 pair of 15mm rails 23" long with 2 bearings per rail
    $70 pair of 15mm rails 32" long with 2 bearings per rail
    Also have 30mm rails left but all 30mm rails with bearings sold. Have about 75' of 30mm rails left im guessing.
    The rail 15mm rail is hiwin HGR15 heavy duty, sells new for $37ft. For bearings for the rail automation4less.com sells the needed 15mm bearings part number HGW15CCZ0H for $43 each and the 30mm bearing part number HGW30CCZ0H for $70 each but can find bearings elsewhere in different brands cheaper
    Also these hiwin rails can be used with these other brand bearings as well, heres a cross reference chart that shows you the part numbers for the other brands
    http://www.controlresourcesinc.com/linprice.htm, many of these bearings can be found on ebay for $20-$30 each
    Nov 2011
    83
    I forgot to add i also have a ballscrew and nut, it seems that it does 1" per revolution, total length of it is 15" with about 12" of it being screw, the ends are machined for mounting in pillow blocks and then coupled to a stepper/servo. I will measure it but i believe it is 3/4", looks new, will take some pictures of it in a little bit
    Nov 2011
    83
    Ok, more info on the ballscrew, it is a thk ball screw model #BLK 2020-2.8, specs can be seen here
    https://tech.thk.com/en/products/thkdlinks.php?id=359
    It seams its brand new, grease zerk wasnt even installed yet
    heres some pictures
    the ends of the shaft are turned down to
    bearing end 1 1/4 depth
    drive end with keyway about 2 1/4 in depth
    the screw part is 11 1/2"
    overall length is about 15"
    the screw diameter is 20mm and has a travel of 20mm per revolution i believe
    I will sell this little gem for $75 plus shipping. Would ship in a usps flat rate box
    Apr 2009
    5516
    If you have any 25mm rails I'd be very interested. I would also look to trade, as I have HSR35 rails and 4 blocks 1240L, SHS15 914L 2 rails 4 blocks and SHS15 600L 2 rails 6 blocks, all NIB... Would need 1200mm HSR25 rails only (2).
    Nov 2011
    83
    Sorry all i have is 15mm and 30mm, no 25's
    15362
    jimmyjames1981
    You can not fit other manufacturers bearings to the Hiwin rails, you can only use Hiwin bearing for Hiwin rails & they have to be the right type bearing also for the rail they are going to fit
    Mactec54
    Nov 2011
    83
    jimmyjames1981
    Well some you can and some you cant, how about this, if you buy my hiwin brand rails make sure you get hiwin brand hgw series bearings.
    15362
    jimmyjames1981
    No not correct, they would have to be made by the same manufacturer, each manufacturer have slight differences in there design so this does not happen
    Mactec54
    Mar 2004
    1661
    Please use the Ad's section for trading.
  1. V-groove guide bearings and rails
    By Dirtbos in forum Waterjet General Topics
    Last Post: 11-07-2011, 02:46 AM
  2. Changing linear guide rails Okuma LT300
    By MIKEL12 in forum Okuma
    Last Post: 07-26-2009, 06:26 PM
  3. Linear guide rails..flat vs round
    By cloudbase in forum DIY CNC Router Table Machines
    Last Post: 10-09-2008, 02:11 PM
  4. How to machine ends of linear guide rails.
    By SES1 in forum Linear and Rotary Motion
    Last Post: 02-12-2008, 09:27 PM
  5. Linear Rails and Bearings
    By Robyn in forum News Announcements
    Last Post: 08-30-2006, 04:10 PM
