586,096 active members*
3,378 visitors online*
Results 1 to 6 of 6
    Jun 2007
    84
    Chuck open output signal
    I'm trying to interface an old 1993 LNS Quickload
    with a 2008 Puma 240B with Fanuc 21iT control.
    All connected, but the control sends out "chuck open"
    signal when it is closed.
    Is there a way to reverse the output?
    On when open, off when closed.
    2932
    IIRC, the newer LNS units I've seen have a way to change the input for chuck open in the barfeed controller itself. I don't believe there's a way to change it in the Doosan. Do you have schematics for the bar feed?
    Jun 2007
    84
    They are at work. If the show stops, I'll be going to work.
    From what I have been able to trace, the signal goes directly into the logic board.
    Our "newer" 1996 model has a parameter option to switch chucking mode.
    Thanks.
    Jun 2007
    84
    Forgot I had the manual in my email.
    The interface connection is on page 36 "USA"
    Hope it helps
    Jun 2007
    84
    Forgot to upload file.
    Jun 2007
    84
    Figured it out.
    Wired in a relay to reverse the signal.
    All is good!
  1. Mach3 output signal
    By salvanosalvador in forum Machines running Mach Software
    Last Post: 04-21-2013, 04:51 PM
  2. Replies: 3
    Last Post: 10-04-2011, 01:50 PM
  3. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  4. Input/output signal on 0M-C
    By padobranac in forum Fanuc
    Last Post: 10-28-2008, 03:49 PM
  5. No Output Signal
    By tz1238 in forum Machines running Mach Software
    Last Post: 01-27-2008, 09:57 PM
