586,068 active members*
4,327 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Chuck open signal needs to be reversed
Results 1 to 7 of 7
    Jun 2007
    84
    I'm trying to interface an old 1993 LNS Quickload
    with a 2008 Puma 240B with Fanuc 21iT control.
    All connected, but the control sends out "chuck open"
    signal when it is closed.
    Is there a way to reverse the output?
    On when open, off when closed.
    2932
    I believe you can change it on the LNS side.
    Feb 2009
    6028
    Ya, thought there was a setting in the LNS for pullback style or dead length style clamping.
    Jun 2007
    84
    Thanks, I'll play with the buttons to see if I can figure out to find the parameter.
    If not, I'll wait until Wednesday when LNS gets back from holiday.
    Jun 2007
    84
    Figured it out.
    Wired in a relay to reverse the signal.
    All is good!
    Apr 2007
    Merhabalar
    Apr 2007
    stainless steel (304) mill
    waiting for your help to track the file handle ..
    machine-AWEA-AF610 (4 axis)
    thank you...TANSA Turnike
    Attached Files Attached Files
  1. Chuck will not open
    By bruiserba in forum Okuma
    Last Post: 08-30-2019, 07:32 PM
  2. Chuck open/close M-codes on 6T-B
    By L98FIERO in forum Fanuc
    Last Post: 01-03-2013, 02:01 AM
  3. Chuck open output signal
    By Don18P in forum Daewoo/Doosan
    Last Post: 12-30-2012, 07:12 PM
  4. run lc 30 with open chuck
    By martin269 in forum Okuma
    Last Post: 07-08-2012, 05:05 AM
  5. Replies: 3
    Last Post: 10-04-2011, 01:50 PM
