I've had my mill for about a month and I've finally ordered everything I'll need to convert it to CNC. I'm using the cncfusion deluxe conversion kit, kelling 570oz/in steppers, KL-5056D drivers, and I have a very beefy 48V 57A power supply that I got for $30 on ebay.
I'm still waiting on all the parts, so I wired up a 240V receptacle near my machine for the PSU. It's "48V" but really ~51.4V. The KL-5056D drivers specify 50V max. I'm sure they'd be fine, but I'd be more comfortable if I could lower the voltage to around 48V. I took it all apart and managed to find a pot covered in silicone that let me lower the voltage, but only down to 50.5V. It's a 1K pot. I removed it and soldered on some wires that run out of the case and attach to a 5K pot with a dial. This lets me adjust the voltage from 45V to 53V, I just leave it at 48V.
I don't have any machining experience, but from messing around adjusting the gibs and using a dial indicator I can tell that the fit sucks. Even if I tighten them so hard that the table is hard to move, I can pull up on the table and see a few thou of movement and see oil sucking in and out of the ways. I broke down the mill and I could feel that the fit is very inconsistent along the length of the table. I ordered a cheap scraping kit and a 9x12x3 granite surface plate (biggest without painful shipping charge). I also got some Dykem blue hi-spot and 400, 600, and 1200 grit lapping compound that Brian linked in his build thread. I've never scraped before, so I might just try to get the gib to fit right and very lightly lap everything else to be a more consistent fit.
