586,113 active members*
3,485 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > How to set up TS27R probe center?
Results 1 to 3 of 3
    Oct 2009
    28
    I had my machine transported and the table came loose and crashed into the tool setter. I replaced the probe but now the tool probe center is out by about .250". How do I adjust the center?
    Thank you
    Nov 2006
    418
    Download the manual from the Renishaw site, it should have the parameters that store the location of the probe as I remember - which you will need to correct. This is assuming you're using the Renishaw programs for tool probing, if you're using custom macros you'll have to read through and find the locations referenced in the them and then fix those (you can also do this with the Renishaw macros).
    Oct 2009
    28
    Ok I'll try that. Thanks for your help.
  1. how to center a homemade touch probe
    By isowe in forum Digitizing and Laser Digitizing
    Last Post: 05-16-2012, 02:23 PM
  2. Wiring a TS27R + optical probe to a Haas
    By DaOne in forum Haas Mills
    Last Post: 03-16-2012, 09:19 PM
  3. how to use ts27r
    By mujib_berkat in forum Fanuc
    Last Post: 08-19-2011, 05:17 PM
  4. Renshaw TS27R probe
    By Fred cnc in forum Want To Buy...Need help!
    Last Post: 03-29-2011, 03:24 PM
  5. Renishaw TS27R Probe
    By dspeights in forum Fadal
    Last Post: 07-24-2010, 12:42 AM
