My contention is that the less plugs/sockets/terminations the better.
But what you may do is use the male pin headers I previously linked to, although they come in .1" spacing and you need 5mm.
The single strips are notched to allow individual separation, you could mount these on a daughter board and space them accordingly to suit the Kanolog terminal entry.
The pins would go under the terminal screws as a permanent attachment, and if required removing just unplug the whole terminal strip?
Either side of the pages in the link show other makes, 3M etc.
Al.
Albert E.
