586,113 active members*
3,212 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > X3 Chuck holder wont go into the spindle.
    Nov 2007
    87
    Hey All,
    I have been switching between my collet holder and my chuck holder on the X3 for years now. Today when I went to put in my chuck holder, it wouldn't go in. I filed the top a touch to make sure the groove was easy for the pin to align with. But no go, it only goes into the spindle about half way. I used my calipers and everything measures the same between my collet holder and my chuck holder. Do any of you know what might be causing this?
    Joe
    Jun 2009
    135
    Take a good look at the aligning pin. Also dykem or high spot blue will usually help identify the problem area.
    Nov 2007
    87
    Today I took the machine down to the spindle so I could get a better look at the pin. While I was in there I polished up all the parts and repacked the bearings. She is running smoother than ever and it turns out that all I needed to do was polish the end of the chuck holder. Guess it had fallen off the table a few too many times.
    Makin chips,
    Joe
  1. moriseiki lathe CL-25 wont let me chuck by ID
    By david rendon in forum Mori Seiki lathes
    Last Post: 12-15-2021, 07:44 PM
  2. Er11 replace collet chuck holder to er 20 to chinese spindle.
    By eptapsyxos in forum DIY CNC Router Table Machines
    Last Post: 11-21-2012, 07:37 PM
  3. Drill chuck holder
    By reedmiles in forum Haas Lathes
    Last Post: 12-30-2009, 06:50 PM
  4. vf4 wont release tool holder
    By panaceabea in forum Haas Mills
    Last Post: 08-25-2009, 11:02 PM
  5. Drill chuck holder
    By GerPen in forum MetalWork Discussion
    Last Post: 01-26-2009, 12:49 AM
