You seem comfortable in editing posts, so I won't state the usual "Save a copy" before doing any edits
To place an empty line, you need to find the correct placement in the post & insert
" ", e$ note....put a space between the quotes
or if you want open/close comments only, then insert
"()", e$
for the placement after the M00/M01 output, look for
Code:
ptlchg$ #Tool change
toolchng = one
if mi1$ = one, #Work coordinate system
pfbld, n$, *sg28ref, "X0.", "Y0.", e$
pfbld, n$, sg92, *xh$, *yh$, *zh$, e$
if prog_stop = 1, pbld, n$, *sm01, e$
if prog_stop = 2, pbld, n$, *sm00, e$
pcom_moveb
pcheckaxis
c_mmlt$ #Multiple tool subprogram call
pcan
"()", e$ <---- HERE
ptoolcomment
pbld, n$, *t$, sm06, e$
pbld, n$, pstagetool, e$
"()", e$ <---- HERE
comment$
result = newfs(15, feed) #Reset the output format for 'feed'
sav_absinc = absinc$
You could try my post in this thread, it is very close... I use () instead of an empty line. It's also got a few "enhancements"
PS it is a 4 axis post, it will not ouput ABC's unless they are defined in the Machine definition file
