586,121 active members*
3,643 visitors online*
Thread: V2 Bugs
Results 1 to 6 of 6
    Jun 2007
    394
    V2 Bugs
    I have been using Bobcad V2 for a few months now (mill and lathe) pro version. I have come across a few bugs. When I create a model , create toolpaths and simulate the toolpaths everything is fine. I post my code and there are no problems. Then close the model.
    However when I reopen the SolidWorks model and add in a new toolpath into an existing setup and compute the toolpath everything gets screwed up in the other toolpaths
    1: Model with existing toolpaths opened
    2: Add in toolpath and click compute all toolpaths
    3: Click Mill Simulation – then click screen fit – this causes model to become transparent
    TO FIX SIMULATION POBLEM:
    4. Exit simulation and expand all previous toolpaths – reselect geometries and start points for each toolpath (no need to actually select the geometry as it is already selected).
    5. When done right click Milling Tools and click compute all toolpaths
    6. Click Mill Simulation – then click screen fit – PROBLEM WITH TRANSPARANCY SOLVED plus a new problem is created
    7. Now toolpath heights and depths are incorrect.
    TO FIX ITEM 7
    8. Edit all toolpaths until correct
    Mar 2005
    368
    Quote Originally Posted by fidia View Post
    TO FIX ITEM 7
    Are you saying that the values in the dialog boxes are being changed???
    Jun 2007
    394
    There are a few problems. Yes the dialog boxes change and the simulation is not right - see pics
    Attached Thumbnails Attached Thumbnails image_1.jpg   image_2.jpg   image_3.jpg   image_4.jpg
    Jun 2007
    394
    The problem only occurs when adding a new toolpath after saving and re-opening the model.
    2 problems are
    1. simulation transparency
    2. toolpath setups change
    Mar 2012
    1570
    Can you report this issue using the following link BobCAM-CAM Software Issue Report, Feature Request | CAD/CAM | BobCAD-CAM
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jun 2007
    394
    Bug reported
  1. Wall bugs
    By skylanehku in forum CNC Machine Related Electronics
    Last Post: 09-28-2012, 02:10 AM
  2. SprutCAM Bugs
    By mgp in forum SprutCAM
    Last Post: 11-29-2010, 11:45 PM
  3. Know what really bugs me?
    By revwarguy in forum DIY CNC Router Table Machines
    Last Post: 03-16-2010, 01:46 PM
  4. X3 Bugs?
    By WingNutz in forum Mastercam
    Last Post: 02-14-2009, 09:47 PM
  5. Bugs in 2005
    By mdlmkr in forum Surfcam
    Last Post: 10-04-2005, 05:45 PM
