586,051 active members*
3,898 visitors online*
Results 1 to 15 of 15
    Mar 2011
    144
    Starting 2nd build
    I have already built ver. 1 of Momus Cnc and its been working fine. But I have decied to build second one and possibly go for screw instead of belt, but I'm not sure yet.
    I will post some pics when I get some.
    Dec 2012
    Hi, why are you thinking of using a thread screw this time round?
    Mar 2011
    144
    Last time I was cutting I tried to go little faster around 180ipm with 1/16 Doc and belt jumped one tooth and I had to scrap what ever I was cutting.
    Dec 2012
    That's very interesting to know. Did you have any other troubles with the belt/machine design? Can I ask what motors and drive you use on your current machine? Will you be upgrading these on the new one?
    Mar 2011
    144
    I used Xylotex drive and it came with 270oz motors , I will use same motors but I got hold of Gecko drive so I will use that one and maybe thinking about driving both sides of the gantry. Never had any other problems with belt. even when cutting aluminum.
    Dec 2012
    Okay, great.
    I am just starting out building a machine. Nice to hear of your experiences. Are there better quality belts/pulleys you could buy or do you think it is just the limits of the belt driven design?
    Oct 2004
    590
    Quote Originally Posted by fastpcuser View Post
    I have to ask what you were cutting. I've driven my machine to a complete stall and have never had a belt skip. At a 1/16 DOC in wood I could easily cut at 300ipm. Are you sure that your belt is tight?
    Chris
    Mar 2011
    144
    I was cutting RC propeller out of poplar with 1/8 - 4 flute bit. It was cutting good for almost the whole g-code, but something happened on one of the passes.
    Sent from my MB860 using Tapatalk 2
    Oct 2004
    590
    There's definitely something else going on there that's not related to belt drive per se. Loose belt, weak stepper motor, low power supply would be my first three guesses. Hope you figure it out.
    Chris
    Apr 2009
    5516
    A 1/8"-4 flute bit may not be the best bit for wood, since you won't create enough chipload to cut efficiently due to the high RPM of the router, and the flutes are smaller, creating a problem as far as chip evacuation. If you're making fine dust it'll pack in the kerf and in the flutes, and that could possibly cause a momentary stall or skipped step.
    I would advise using a 2-flute or even a 1-flute carbide endmill.
    Mar 2011
    144
    I'm still thinking if not change the design little bit and go for 80/20 and THK linear rails and actuator which I have laying around. which would be better 80/20 or plywood ?
    Nov 2005
    15
    I would be interested in hearing about the work flow you follow to cut a propeller.
    Mar 2011
    144
    The propeller I was cutting was only 12" for RC Plance cut from 3D model using Cut3D
    Nov 2005
    15
    Did you design the prop model to load into Cut 3D, or find one online?
    Mar 2011
    144
    I found one online and compared it to one I had its was 12x6, I cut it in 10x6 as well. You just have to be carefull when flipping it to do other side so your center don't move.
  1. Starting to think about my next build
    By gully in forum Australia, New Zealand Club House
    Last Post: 05-03-2012, 12:51 AM
  2. Starting up 2nd New CNC Build
    By JTK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-04-2010, 03:36 AM
  3. Starting my build..
    By djmickyg in forum CNC Wood Router Project Log
    Last Post: 10-31-2009, 12:57 AM
  4. starting my build soon
    By justin22885 in forum DIY CNC Router Table Machines
    Last Post: 07-27-2009, 03:42 AM
  5. New build starting soon.
    By Kammo1 in forum DIY CNC Router Table Machines
    Last Post: 03-23-2006, 09:25 PM
