Hello everyone!..
I'm fairly new to the machining world, and I'm looking for someone help.
I need to mill a 45 degree 15 MM chamfer on this part. The tool I'm using is a 45 degree index-able endmill. The inserts are about .300 from the center of the tool.
How do I program the machine, using Acu-rite control and readout system. Do I just program a straight line 15 MM into the part?? Also I need to give the diameter of the tool. Do I then tell the machine its the smallest diameter of the tool (bottom of the inserts) or the largest diameter (top outer tips of the inserts)
Any help would be much appreciate any help!!
