586,075 active members*
3,982 visitors online*
Results 1 to 12 of 12
    Oct 2012
    72
    Your Favorite Material
    Just wondering if anyone has a favorite material they like using with there laser cutter?
    Sep 2012
    55
    My wife likes anything that I make out of 3mm clear acrylic because it provides function whilst being almost invisible. I personally hate working with the stuff due to the variability in its thickness even within the same piece. This makes interlocking pieces a right pain.
    My favourite material is 3mm Beech plywood. It has the beauty of a natural product, is structurally stable and strong (not brittle like acrylic) and is cheap to buy. It can be stained, varnished, painted or just lightly sanded which is what I do most of the time. I make anything I can from this material.
    Sep 2011
    296
    I have many nice works photos by my customers for acrylic, wood, silicone, cloth... Engraving on glass really looks beautiful although it needs high operation skill of lasers. And the natural burn marks on wood also looks great.
    Oct 2010
    67
    I like any material that cuts cleanly at the speed it should
    Oct 2012
    72
    Quote Originally Posted by DavenUK View Post
    Like which ones?
    Oct 2010
    67
    Mainly mdf, ply or acrylic - I buy in small quantities so batch differences are a pain ;-)
    Dave
    Jan 2013
    Hello, I have only cut with metals but my favorite of them is Stainless Steel. My machine cuts so nicely and if you have decent material that isn't scratched or mishandled any etchings on it come out perfect.
    I also like to use 1mm aluminum and sand blast the material before etching, provides a good solid cutting surface unlike unsanded aluminum. Only problem is with the thinner aluminums you have to be careful of sandblasting for to long, you will end up warping the material.
    Apr 2006
    251
    I like MDF and acetal (delrin). I too hate the sloppy tolerances of acrylic and the smell it gives off when being cut. Plywood is OK but lately it has been difficult to get hold of decent quality laser ply.
    Oct 2007
    385
    I am a fan of 3mm plywood. The only problem I have is the fact that some of the wood being used varies in hardness. At times I can cut through the 3mm plywood with the settings on my 40w laser set to 8 speed and 23 power (about 8.5ma). At other times I have to slow down to 6 speed to cut the same thing out. It just varies too much. I also like to cut acrylic. It also cuts differently every time I use it. Bass wood us easy to cut, but it is much like balsa. I cut 3.2 mm basswood at 15 speed and 16 power. Pretty much cuts like balsa. I also use slate, or shale for doing photographs. If I make a mistake, I only need to sand it down and start over again, no wasted material.
    Milt
    Jan 2010
    My favorite materials: plastic laminate like Formica. It cuts very cleanly, holds very thin lines for silhouettes, and can be glued with white glue. The only problem is keeping it flat.
    Corrugated Cardboard. It is a great material for prototyping: free, and widely available. Cuts very fast.
    It also gives off Formaldehyde and Ammonia fumes. Formalin isn't too bad but ammonia isn't good
    best wishes
    Dave
    Mar 2012
    112
    Acrylic, by far, it's just so damn sexy lasercut.
    Although next on my list would be engraving anodized aluminium, especially black, which is also quite sexy
    Build logs and other projects of mine: http://nqlasers.com/
  1. How to Change Focus Lense
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-03-2013, 12:40 AM
  2. Table Height?
    By Jeep07 in forum Waterjet General Topics
    Last Post: 11-11-2010, 07:32 PM
  3. spherical fresnel lense
    By coykiesaol in forum Mechanical Calculations/Engineering Design
    Last Post: 11-03-2010, 01:03 AM
  4. Setting Table Height
    By Sam A in forum Commercial CNC Wood Routers
    Last Post: 03-07-2009, 10:57 AM
  5. Table Height
    By schoobie in forum Torchmate
    Last Post: 03-24-2008, 04:17 PM
