586,398 active members*
2,888 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Difference between Round and square Guide Rail
    Nov 2012
    Lightbulb Difference between Round and square Guide Rail
    There are two types of guide rails: the square (profile) guide rail and round guide rail. Round guide rails originated first but do not provide the precision offered by square guide rail components. However, the round guide rail is the preferred guide rail for vertical movements with heavy loads. The application will dictate which type of linear guide rails should be used.
    While square linear guide rails once cost many times more than round technology due to the extensive grinding requirements inherent in the design, new manufacturing techniques and economies of scale have encouraged engineers to entertain the use of square guide rails in a broader application space. Profile linear guide rails can now be found in many of the same applications that were once only supported by round guide rail.
    Square (profile) guide rails can outperform round guide rails in specific circumstances that demand higher rigidity and more compactness in terms of load capacity relative to size. In general, profile rail guide rails offer higher load capacity, accuracy and stiffness, and a longer life expectancy.
    Aug 2011
    388
    Jan 2013
    12
    useful article
  1. Difference between rod and round tube
    By Einars in forum Linear and Rotary Motion
    Last Post: 12-21-2012, 03:16 PM
  2. Square peg in a round hole?
    By Ironic in forum ArtCam Pro
    Last Post: 09-16-2012, 06:07 AM
  3. Square instead of round pipe
    By kennethagius in forum DIY CNC Router Table Machines
    Last Post: 03-07-2009, 12:19 AM
  4. A good article on round bearings (bushings) versus square rail slides
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 11-20-2007, 02:19 AM
  5. cheap round rail linear guide stand-offs?
    By hardyn in forum Linear and Rotary Motion
    Last Post: 12-22-2005, 04:09 AM
