586,119 active members*
3,644 visitors online*
Results 1 to 7 of 7
    Jan 2013
    Smile New to the CnC world
    Hello
    Im Shaheen
    i hail from the UAE
    We are in the swatch book making company and usually cut MDF woods of 3mm to 4mm for our books usually about 150 boards/ order of 121.9 x 243.9 cm MDF boards. and each book size usually varies from 140cm x 45cm to 100cm x 35 cm
    And different kinds of material from paper boards of 3 mm thickness to MDF boards of 4mm thickness
    And per order its usually a specific size of the book that we require
    so we ve decided to go the CnC router way
    we have decided on this machine for cutting (ONLY CUTTING) the MDF in the required sizes
    High Speed Advertising CNC Router,Cutting Plotter
    Your feedback on the drill bits required as well as other inputs and suggestions would be greatly appreciated.
    They would also be providing type 3 software bundled with the machine.
    Please keep in mind that this is my first time with such a complex machine.
    Thank you in advance for aLL the help.
    Jun 2009
    135
    Find out the difference between drills, end mills, and router bits. End mills and router bits are needed.
    Jan 2013
    Thank you, I just did a google search.
    It seems mighty complicated.
    What sort of Router bit should i use to cut through a 4mm Board of MDF clean and also 2-3mm kappa boards?
    Regards
    Shaheen
    Jul 2009
    419
    If you mean kappa board as in cardboard, that is probably hard to cut cleanly. But it may work if you use what is called a down-cut or negative spiral end mill.
    With the normal rotation of the spindle these push the material down to the table during cutting where normal up-cut or positive end mills have a tendency to pull the material up.
    Probably works well on thin mdf as well.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Jan 2008
    940
    for the cardboard you may want to use a drag knife and not a bit.
    Jul 2009
    419
    3 mm is just under 1/8th of an inch, can you cut that with a drag knife? I have trouble doing that by hand...
    Sven
    Jan 2008
    940
  1. New to the world oc cnc
    By Toboldlygo in forum Stepper Motors / Drives
    Last Post: 11-06-2011, 11:38 PM
  2. Hello world
    By jgramlich in forum Community Club House
    Last Post: 05-17-2011, 12:25 PM
  3. New the the CNC world
    By dantyler34 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-17-2011, 01:51 AM
