Hey guys, was hoping some of the experienced people could help me with some problems I'm having trying bore pulleys for my belt drive conversion. I have 4 - XL Timing Pulleys I purchased from econobelt that I'm trying to open up the bore on. I have 2 with .5"bores that I'm trying to open up to .853" and two pulleys(one .375" bore and one .5" bore) that I'm trying to open up to a .669" bore. This is actually my second attempt as the first attempt appears to have been a disaster. So I ordered a new set of pulleys and want to be sure I get it right this time. I don't have a lathe, so the finish boring will be done with a a boring head on my G0704.
The problem I had with the 1st attempt appears to be that the bore and OD are not concentric so I'm getting woble and having the belt thrown off. I first verified this by using calipers to measure the distance between the center bore and a pulley tooth in various positions. I forgot to write down my results, but there were discrepancies. To further verify, one by one I checked each pulley by using an interapid .0005" indicator in a spindle indicator holder. I had each pulley in the vice and indicated off the center bore making table adustments until I had about .0004" runout on the indicator when rotating the indicator (this is one procedure for centering a hole, correct?). I then repositioned the indicator to read from the OD. On the worst pulley I got .012 of runout on the OD. All of them showed .005" or worse.
So my first question is, am I correctly checking the concentricity of the ID and OD? In relation to this question, another problem I'm having is indicating off the teeth of the pulley. Depending on where on the tooth the indicator is positioned, the reading can vary up to .003". What I mean is that if I start to sweep the indicator across the tooth, the measurement can vary .003" depending on it's left-right position on the tooth. My experience thus far seems to be that the highest point on the tooth seems to be at the right edge. My instinct is to take the indicator reading at the highest point on the tooth. Is this the way to go, or should I perhaps be indicating of the valleys between teeth? I'm not sure the valley's are wide enough to have the indicator tip resting on a flat spot and not being cradled by the sides of the adjacent teeth. Using the method I described above(centering on the center bore then indicating off the teeth), I checked the new pulleys from econobelt and found .0015"-.003" difference in concentricity between the ID and OD(based on using the method I previously described). What is acceptable concentricity to achieve a smooth rotating pulley?
My procedure for boring the pulleys last time was this:
1. Center pulley to spindle by indicating off the bore using an indicator holder mounted in the spindle and adjusting until I had .0005" or less runout.
2. Using circular interpolation to open the bore's to within .03" of final desired bore size.
3. Using boring head to make several passes to final bore size.
Could the circular interpolation have been my problem? Should I have allowed for more material removal by the boring head? Would using a drill bit(as opposed to interpolation) be a better option for getting me close enough to use the boring head to finish the bore? I didn't have any drill bits over .5" which is why I went with circular interpolation, but I'm not opposed to buying them if that's going to be a better option.
For my last question, the reason I have 4 pulleys is that I'm going for a 2-speed setup. For this, I need to mount the pulleys together in pairs. One smaller pulley on top of a larger pulley. For my previous attempt, I indicated off the bore on each pulley to center the spindle and ran a program to drill 4 holes. Same program for each pulley. However after all the concentricity checks I've ran, I've determined the two pulley are not mounted together concentric to each other either. Any suggestions for ensuring concentricity when mounting one pulley to the other? Any and all feedback to my questions is greatly appreciated guys. I'm still very much a noob and learning as I go so I rely heavily on what I read about on the forums. Thanks in advance.
-Kevin
