I need help finding a plate cutter for hobby work.
I need to cut aluminum material up to 3mm (1/8") or so.
Steel up to 2mm or less.
The maximum cut width could be 50 cm or approx 20 inches or so.
I only find huge models intended for commercial shops but they are all too large and too heavy. I have my shop in the attic now so I cannot safely fit a large machine that weighs 800+ punds.
Max weight I would say should be 100-150 pounds or a bit more.
The cutter should be of a type that cuts evenly and not a "swipe" type if you know what I mean.
I have no problems importing a machine from the USA as there is no rush. I have a good sea-freight provider that I use all the time from the USA to Europe with reasonable prices.
