586,540 active members*
2,885 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC 30 SSM Ultimax 3
Results 1 to 7 of 7
    Jan 2013
    Dear friends,
    I own the above mentioned machine. I had the problem that my bios battery got low. I got it fixed with putting an external CR2032 battery to it.
    Now I have another problem. It says operating system is missing.
    I unplugged the hdd and I found out it was splitted to a 10 MB drive with name EXECUTIVE_1 and some files in it and another drive with name PART_PrOGS ..
    Homever I am stuck now, because I don't know what to do. Please give me some advice.
    I think my Floppy on it works ok, but I don't have any files to start from scratch.
    Has anybody some actual files so I can work on the machine again.
    On the old software the G0 in the program could not be handled with the rotator button and this was often a problem for me. Can somebody help me on that too?
    Thanks in Advance from Germany.
    Bernd
    Sep 2012
    if your battery was problem, i think your bios settings restarted. For Ultimax settings for hard disk has to be specificed, like cylinders head and setor numbers ( usually is 3303 16 50 ) so go to BIOS and check this settings. You can send me which software you got and what CPU board is present, or attach BIOS photo.
    Darko
    Jun 2008
    1104
    If you are running version1 software, use:
    Cylinders 1024
    Heads 16
    WPCOM 65535
    Lzone 0
    Sectors 50
    Leave it set to CHS mode
    OR
    If you are running version2 software, try:
    Cylinders 3303
    Heads 16
    WPCOM 65535
    Lzone 0
    Sectors 63
    Change mode to LBA after setting.
    Jan 2013
    YEY THAT WORKED.. AWESOME GUYS!
    Now I am running on software V1.64
    I heard there is a later one than that.
    Can you provide me with an update for this Ultimax machine?
    Thanks in advance
    Jun 2008
    1104
    You could upgrade it to version2 but it would need a security modifier to allow it to run. The latest version1 software was V1.65 but it was only minor bug fixing on a rapid response build.
    Jan 2013
    Hey Bloke,
    if you show me how to put Version 2 software on it I'll give it a try ;-)
    Jun 2008
    1104
    You'd need to upgrade the dongle to allow it to run version2. A simple enough thing to do if you work for Hurco and have a copy of Millkey or have an Optikey disk.
  1. SOLVED...Hurco 40 SLV, Ultimax 3
    By SINUMERIKO in forum HURCO
    Last Post: 02-25-2020, 03:47 PM
  2. Hurco Ultimax II
    By gregm1976 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 08:11 AM
  3. Hurco BMC 20 - Ultimax 3
    By arvishal in forum HURCO
    Last Post: 10-03-2008, 08:57 PM
  4. Ultimax 3 for Hurco
    By Nong Noy in forum Post Processors for MC
    Last Post: 08-16-2008, 04:02 PM
  5. Hurco KM3 w/ Ultimax
    By Mr. LocoMartin in forum HURCO
    Last Post: 01-14-2008, 03:18 PM
