586,108 active members*
3,322 visitors online*
Results 1 to 2 of 2
    Nov 2008
    61
    Mill/Drill Flood Coolant Enclosure
    I thought I would present my plans for my enclosure for my mill for people to give ideas and suggestions before I begin the build in case you can think of anything changes or suggestions that slipped my mind. Below are a few shots for my mill. It is a microkinetics CNC express mill, yes it is mill/drill and you may ask why I would spend so much time and money on making an enclosure, well thats because it is what I have, I teach metalwork at a high school shop and it is out only mill and what I had to work with when I came to the school. It has been pretty good to me since I worked out the kinks, and other than a 5 inch Z axis limit on the CNC part and some backlash I cannot get rid of, it works.
    So my enclosure has gone through a number of changes and modifications over the past few months. This is the final version, inspired by two indaviduals that I want to acknolege before I show my pictures.
    My enclusre is based and inspired by Guldberg's design
    The base was going to be the same until I saw mikemaats baseMikemaats base and loved the idea of storage for more than just a coolant tank, in fact I intend to put my electronics and vaccum below. Thanks guys.
    So I plan to build the enclosure in two stages, the first the base and pan with sheet metal covers completed, painted and mill sitting on it so I can use it asap. I will then build the walls of the enclosure minus sheet metal and bolt them on (they are removable for maintenence). I cannot afford sheet metal this year for the walls so I will use plastic sheeting for the time being to make it work.
    All drawings made in Rhino 4.0
    Materials are:
    Frame: 1x1 Tube
    Base Frame: 2x2" Tube
    Sheet metal - 16ga
    Pan 1/8"
    Windows - 3/16 acrylic sheet
    Doors - sliding
    Oh and I could not get the pictures to display, I used the insert image option above but they would not work so I posted the link instead.
    Front View
    Top View
    View of Base
    Drain
    Nov 2008
    61
    I do not know what is going on, I have to log in every time I click any button like post or preview or something and my links are all to the same picture, and I cannot edit my post so here are the links, hopefully they work, checked before I posted and they worked.
    Front.jpg -Front
    Here is the front, looks like a little VMC, two sliding doors to allow access.
    Drain
    Here is a shot of the drain behind the mill. it will house a screen to pull out and clean, under the screen will be some foam that will help further filter. It will drain directly into the coolant tank.
    Front Cab.jpg - Cabinet
    Shot of the front of the cabinet, center part if the coolant tank, big I know but I like lots of flood to clear chips, right side will get a wall to seperate from the coolant tank and house the controller and computer. Right side will get a vaccum.
    Top.jpg - Top
  1. What flood coolant is good for Taig Enclosure
    By Menacer in forum Taig Mills / Lathes
    Last Post: 02-13-2013, 05:59 PM
  2. CNC Mill Flood Coolant Cabinet
    By 1moreproject in forum Benchtop Machines
    Last Post: 09-28-2010, 10:46 PM
  3. Flood Coolant Enclosure
    By Mini Beast in forum Taig Mills / Lathes
    Last Post: 09-19-2010, 05:40 AM
  4. Pictures of my flood coolant table for my CNC mini-mill
    By InspirationTool in forum Benchtop Machines
    Last Post: 10-11-2006, 06:06 PM
  5. Flood Coolant with spash guard kit for Knee Mill?
    By scorpion in forum Knee Vertical Mills
    Last Post: 06-27-2005, 07:25 PM
