So I was just about to go through and start testing out my rotary attachment and noticed that most of the o-rings are completely shot... Anyone have any idea where I might be able to pick some new ones up at and what size they are?
Wow 67 views and not a single response.. I guess Im SOL!
if it's the one I'm thinking of, I think you want a 2.5mm width and 50mm inside diameter. You can get it from mcmaster carr PN:9262K452. hopefully that's the right one
What about getting some from GWeike?
Just take them down to the local bearing shop, they will have a range of o'rings.
Hi ,
I had a 2.5mm width ,D more than 60mm rings at hand .There are many different types of rings on Rotary . You may measure the size,D of O rings and confirm with the manufacture . Then go to local shop and buy some . Also you can contact and bought from manufacture directly ,but will cost more time and expenses.
XYZ Machinery
Hi Phil,
If so, the size will be outside diameter is 55.3mm inside diameter 50mm,thickness is 2.65mm,
I just leave message on Skype, did you get it ?
Best Regards
Lucy Lee
G.WEIKE LASER
[email protected]
Phylo,
We have these in stock as this is a common problem. Call our office 855-552-7377 and we can ship you them. It is $9.95 for 20 O-rings + shipping.
Hurricane Lasers.com
As I said, local bearing shop.
There'll be one near you.
Take the rotary and the old o-ring with you.
Here is one I looked up. 25 pages of o-rings listed,
DUD LINK
I applaud Hurricane lasers for having them in stock and available, but it is a bit like sending to Nevada for a paper clip.
Greolt
EDIT. OK the link did not work but you get the idea.
Order 50pcs from McCaster for 11.65+shipping. If you're near a major city (at least on the west coast) they usually deliver next day as long as you order by 6pm.
McMaster-Carr
PN: 9262K452
