Hi All,
Appologies up front if this has been asked before. However, as I have searched I havent been able to find an answer to this question. My dilemna is this!
I need a 5 axis machining center or a variant thereof to machine engines, heads, parts, etc.... what I dont need is the price associated with automotive/truck industry.
I would consider a used machining center but I dont have the knowledge of the following:
1. Knowledge of the different brands of used machines that are 5 axis.
2. Knowledge of the different brands of used machines that are less than 5 axis but can be converted to 5 axis by mixing and matching parts.
3. The correct size of a used 5 axis or one converted to 5 axis that I can fit typical sized Auto V8's, Straight Sixes, typical heads, etc...
4. Price is key... I can rebuild anything even if its junk all the way down to PC Board Component level.... Meaning if I have to make an entire new controller board from scratch or anything else I can easily do this. Think outside the box here for any ideas or suggestions?
5. I am in the market now for this so if there are any businesses out there that have this equipment or what I need please feel free to contact me.
Although there maybe equipment that is affordable in price range I havent been able to find it... except maybe from time to time, so my next thoght was this.
I have the capapbility to build my own machining center as I have already built a smaller 5 axis machine center that is very specific purpose with used Robotic parts, tracks, etc... its quite large and takes up a space of 25' x 12, gantry type, and has a rocking bed... so actually, it would be more than 5 axis. I primarily use it for modeling very large full size parts, cars, doors, engines in composites... Anyways,, my thoughts are to create something similar again smaller for machining engines, heads etc... obviously I need to have the tolerances as a machining center but I can also build this. I have no issues with custom programming, building or designing boards, motors, drivers, PS's, etc.... I am more than saavy to take this on.....
The age old question is just because someone can do something it doesnt mean they should!
So, here is where I need input so Im not re -inventing the wheel.... if you all know where I can pick up a cheap used beatup 5 axis or 3 axis to convert... Or any of our advertisers? that would meet my needs could you guide me this direction or to these businesses that can meet my needs? OR,,, is there someone out there who has already built something that I can duplicate with the same needs that I have?
Thanks again,, I hope I have posted this in the correct area and I appreciate all your suggestions in advance.
John
