Hi
After a bit of help and advice with regards to a Mazak QT20N with a T2 controller.
I was setting up and running a test program as the machine is new to us, measured all the tools on the tool eye set Z-0 and ran the program however as the tool approches in X it stops way short and starts cutting, the controller will say X 50 but in fact the tool is at X 90.0.
The other problem I am having is setting the offset for the drill holders I can't find a refrence for the defined X offset to be entered.
Is there a parameter setting for the tool eye?
We have just changed the machine from imperial to metric and adjusted all the B parameters to suit.
Regards
Will
