586,677 active members*
3,114 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > New motors need new drivers
Page 1 of 2 12
Results 1 to 20 of 27
    Apr 2003
    38
    i am replacing the slo~syns with the Vextas
    I need new drives and power supply
    What would you guys suggest
    Apr 2003
    38
    Ok i would like to use the vexta motors with a Gecko G540.
    what would I need to get the best performance out of them using a 1/2 -10 acme?
    i have a 24 volt power supply. but i do not remember the amps.
    Would there be a better driver to use? ( i believe the G540 would give me more options ing the future)
    Will 24 volts be enough for the 5.4v / 1.4 a motors?
    How do I figure out the amps of my power supply or should I build/buy another?
    Jan 2010
    2141
    You have not provided much information, so it's hard to give any definitive advice. Do you have any more detailed specs for the motor? What is the intended application? What are you looking for in terms of performance?
    Is there any reason in particular that you chose that motor? Did the Slo-Syn motor perform adequately, but it failed, or is there some other reason why you are replacing it? What drivers were previously in use?
    That motor apparently has 6 wires, whereas the G540 is designed to drive 4-wire motors. You will have to make a decision about which of the 4 wires you will hook up, and then tape off the ends of the other two wires so that they can't get shorted out.
    What kind of power supply do you have? Maybe a photo would help.
    Apr 2003
    38
    Vexta 125oz/in Stepper Motor Specification
    Model # PH268L-21
    6 lead motor
    1.5Amp/phase 5.4V
    I have a 2" x3" I was running 2 motors on the the X with 1/4 - 20 allthread"slo~syns too week" I am swithing the X to one motor
    Faster than 6 IPM
    I have them already
    They are wimpy I think they are .30 oz i was running them on at 24 volts
    based on the L297 controller "John Conrad Kleinbauer "
    Thinking a G540 would give me room for an upgrade later.
    I am open for suggestions and options
    I built it awhile back and do not remember the amps
    There is no markings on the transfomer
    I get 0.1 resistance on the seconary
    hope this helps
    Attached Thumbnails Attached Thumbnails Power supply.jpg   IMAG0413.jpg   IMAG0414.jpg   Transformer top.jpg
    Jan 2010
    2141
    I am not sure that I can give you adequate guidance, as there are still some unknowns about the motor. For example, we do not know the winding inductance. Perhaps someone else who has experience with similar motors could chime in. But you could certainly give it a try.
    The G540 would seem to give you options for future upgrades.
    The power supply looks like it should be more than adequate to run your motors. One way to figure out how much current you can get from the power supply is to hook up some different test loads to it and measure the output voltage under load (to verify that it does not drop too low). The transformer looks hefty enough that it ought to be able to easily handle at least several amps (and probably a whole lot more). The BR2510 diode bridge has a maximum current rating of 25 amps, so you should be good to go with it.
    35538
    A HobbyCNC drive for $70 will be your cheapest option.
    As a guess, with those motors, 24V, and 1/2-10 acme, your looking at maybe 30ipm best case.
    The G540 might give slightly better performance, but unless you change motors, screws, and power supply as well, you're just spending 4x more than you need to.
    Apr 2003
    38
    Thanks guys
    I ordered the hobbycnc pro figuring the money savings "g450" + the Idle Current Reduction I am still ahead.
    So I am planning on useing the power supply I already have.
    How musch trouble could I expect if it is under Amped.
    I used power resistors on my first board
    Will i be needing them on the hobbycnc board?
    35538
    No resistor needed. Torque is proportional to current. The less current you supply, the less torque you'll have.
    Apr 2003
    38
    Dave was fast (about 3 days for delivery)
    Finished the HobbyCNC PRO Kit (about 3 hours)
    Test came out 5volts
    Attached Thumbnails Attached Thumbnails IMAG0423.jpg   IMAG0425.jpg   IMAG0426.jpg
    Apr 2003
    38
    Out with the OLD and in with the NEW
    OLD
    NEW
    However I am having a problem with the Current Adjustment.
    I can not seem to achieve .21 volts. I can get much higher readings
    Is it me
    My meter
    or am I backassward
    Attached Thumbnails Attached Thumbnails IMAG0428.jpg   IMAG0432.jpg   IMAG0433.jpg
    Jan 2010
    2141
    Quote Originally Posted by ropewrench View Post
    OLD
    NEW
    Is it me
    My meter
    or am I backassward
    I think that I see your problem.
    You should be using the 18-year-old Glenlivet, not the 12.
    Also, from your photo I can not tell what your meter is set to or whether you have the probes connected to the proper test points.
    OK, it looks like your Fluke meter is auto-adjusting. While I generally like and respect Fluke equipment ('if it works well, it's a Fluke'), I'm greatly suspicious of readings taken with that particular auto meter. The display shows that the meter thinks it is supposed to be reading resistance (ohms), but you should instead be reading volts.
    Can you get hold of a cheap Harbor Freight meter, put it on the lowest DC volts scale, and report the reading?
    Apr 2003
    38
    My thinking too
    It should have been the 18 yr
    However this is a budget build and we gota use what we have.
    The Fluke is a auto so I do not have settings.
    My other meter is toast. Brother in law
    Ok off to harbor Frieght
    Check back later
    Apr 2003
    38
    seems right
    got a meter and it seems right
    All 4 adjusted to .21 for 1.5 amp motors
    Apr 2003
    38
    One motor hooked up and seems to be good
    Apr 2003
    38
    Gota love the prices
    99 cents for 8 ft of shrink
    Apr 2003
    38
    AHHHH so close
    Here we go
    I put the controller box together With the the power supply
    Checked wires refitted everything.
    Crossed my fingers and powered up
    They started Hissing at me. Shut it down and looked it up
    SAFE.
    Hopped into Turbocnc and started setting It up
    X putter and erratic Ramped up the numbers and it smoothed out
    Y ran like a top
    Z Doesn't spin. Locks up on power up
    Pulled the board to re check solder Again.
    Found one of the Mosfits on Z was backwards.
    Flipped it and tried it again.
    Z is still down
    What kind of damage did I do?
    KellY
    Mar 2007
    2083
    which fet did you put in the wrong way round Q5 or Q6 ?
    they are both in the auto current reduction circuit
    damage to Q5 would affect the control of the SLA7078M pins 17 (sync) and pin 13 (V ref)
    Q6 just controls the ref volytage to pin 13
    if Q5 is working you should see the voltage on the positive terminal of C 17 change as you step the Z axis
    its possible one of the 6 inverters in U9 (74HC14) has been damaged if an output was connected to the +5V supply by the reverse connected FET
    John
    Apr 2003
    38
    Thanks John
    It was Q5
    and I have 5 volts at positive terminal of C 17 to, but no voltage change while moving Z
    What are my other checks
    Thanks Kelly
    Mar 2007
    2083
    to test your board
    when the Z axis is not being stepped the voltage at C17's positive terminal
    should be at a logic 0 ( no more than +1V)
    this is the input to U9 pins 3 & 5 and the outputs on pins 4 & 5 at logic 1 , that shouild be more than + 2V (typically 4V)
    with a logic probe you should find the Z axis step pulses on U9's pin 1 and
    the inverted step pulses at pin2 which is connected to Q5's gate terminal
    if you only have a voltmeter you may be able to see a change in voltage
    at pins 1 & 2 if you step the Z axis at a high speed
    to test the logic levels on U9 pins 1 & 2
    it could be easier to see if you changed mach 3 to send the direction signal
    to the Z axis step output , printerport pin 7(?)
    check the level , change the "direction" and the level should change 0V to 5V or 5V to 0V
    if U9 works OK you could remove Q5 and use a wire link to connect the source and drain connections until you can replace Q5 with another BS250P FET
    if you don't see any change at U9 pin1
    it could be U 9 is faulty and Pin 1 is short circuited within the IC
    or you have a problem with the printerport or the SLA7078M stepper IC
    sockets for the 74HC14 IC's would of made things easier
    if you look at the X axis
    the step signal connects to U8 pin 1
    the inverted step signal ouput from pin 2 is connected to Q1
    when you step the X axis you should see the voltage on the positive terminal of C 15 rise from logic 0 (0V to +1V) to logic 1 (+2 to +5V)
    this is voltage is connected to U8 pins 3 & 5
    when you have a logic 1 level at U8's pin 5 pin 6 goes to logic o , thats Ov
    and this switches on Q2
    this connects +5V to R1 and this increases the ref voltage to the X axis
    for the Z axis
    when you have Q5 working or its replaced with a link connecting the source and drain terminals you should find U9 pin 6 goes low
    this switches on Q6 to connect +5V to the junction of R17 & R19
    increasing the ref voltage at TPZ
    John
    PS do you have the circuit diagram for the board ?
    http://www.cnczone.com/forums/joes_c...c_-_mach3.html
    I must have a look to see why I'm not getting the email alerts
    Apr 2003
    38
    Here goes
    C17 is 5 volts but so is C15 C16 and C18
    I do not have a probe
    And there is a problem with the LPT port
    I am using turbocnc / Dos
    Z step 7 No change 3.357 v
    Z direction 6 No change 3.357 v
    X step 3 3.367 v Drops while moving
    X direction 2 OL to 3.365 v
    Y step 5 3.367 v Drops while moving
    Y direction 4 OL to 3.365v
    I have another pci card wiht a 25 pin but I do not remember how to get it to boot in Dos
    Windows sees it but doesn't have the drivers for it
Page 1 of 2 12
  1. Stepper motors drivers
    By watzmann in forum Stepper Motors / Drives
    Last Post: 03-08-2012, 03:29 PM
  2. Which motors and drivers?
    By Odie9 in forum Joes CNC Model 2006
    Last Post: 02-13-2012, 11:28 PM
  3. Which motors and drivers?
    Last Post: 02-10-2012, 03:42 AM
  4. How large motors can be used on my drivers?
    By jaru-eri in forum DIY CNC Router Table Machines
    Last Post: 09-22-2009, 08:58 PM
  5. Help with motors\drivers
    By wired in forum DIY CNC Router Table Machines
    Last Post: 01-03-2005, 06:17 PM
