586,077 active members*
3,591 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Best paint for a coolant tank
Results 1 to 9 of 9
    Nov 2011
    15
    I'm building a stand for my CNC mill from welded steel plate, and am trying to find the best "paint" to coat it with.
    My design is like a Haas Mini-mill, where chips and coolant all fall down into the bottom of the stand, which is steel. Any suggestions for paint that I can use that will hold up against coolant? Epoxy Floor Paint?
    Walt
    Feb 2007
    473
    I use the 1-part 'epoxy' floor paint for a lot of stuff around the shop... It's pretty durable from what I've seen.
    As I understand it though few things are going to hold up better than powdercoat. It might be worthwhile looking around to see if there are any local powdercoating places. I don't think it's that expensive usually.
    May 2004
    4519
    Powdercoat.
    Jun 2007
    3757
    Powdercoat.
    Apr 2006
    3206
    Save your money and use Krylon.
    Soon after, when you're tired of fishing out flakes of paint and disgusted with the rust, swear at me and send it out to powdercoat.
    Nothing comes close to powdercoat in its price range in terms of chemical and abrasion resistance.
    -Sol
    http://www.orangevise.com
    Jun 2007
    3757
    And you can get it in white to see when the tank needs a clean.
    Grab something with powdercoat on it. It is so well adhered to the surface that grinding just thins it until you get to the metal.
    Properly prepared surface will remain coated for years, and you just pay someone else (not a fortune either) to do it.
    Oct 2005
    332
    If it is small I would do it in stainless. Probably the cost will be similar and it will last longer than the powdercoat. In theory it will last longer than... you. To clean it you can be "at will" and you do not need worry about damaging the coating.
    Nov 2011
    15
    Thanks for everyone's input. At this point, since the weldment is already complete, I'm leaning towards coating the exterior with epoxy floor paint, and leaving the inside uncoated.
    The exterior will only see occasional exposure to the coolant (splashing & etc), and the inside that is holding the coolant will never rust because of the rust inhibitor.
    The stand weights about 275lbs, so I'm not sure my local powder coater could handle it - but I will check to be sure.
  1. coolant tank for ZL-25B/500
    By Wheels600 in forum Mori Seiki lathes
    Last Post: 12-19-2012, 03:10 PM
  2. Coolant Tank Paint Peeling
    By JohnJW in forum Haas Mills
    Last Post: 11-26-2011, 02:36 AM
  3. Coolant Tank
    By bookerandrew in forum Bridgeport / Hardinge Mills
    Last Post: 03-13-2010, 06:52 AM
  4. Coolant Tank Paint
    By dkaustin in forum Tormach Personal CNC Mill
    Last Post: 01-24-2009, 10:14 PM
  5. Coolant Tank
    By GITRDUN in forum Haas Mills
    Last Post: 09-15-2006, 06:00 PM
