586,069 active members*
3,445 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > How to manually set work offset for Z
Results 1 to 7 of 7
    Apr 2006
    235
    I've been spoiled by the probe and I can't figure out how to manually set multiple work offsets with Z value. Currently, I set all Z work offset G54, G55, G56 to zero and compensate for the varying work offset heights in the program, ie add (-.200) to Z value for G55 and etc.
    Is there a better way to do this?
    thanks,
    John
    May 2004
    4519
    Check the manual. Call up the tool you wish to use for setting. Touch it to the G54 work zero point. On the work offset screen, highlight the G54 Z value. Press the work offset measure button. Repeat process for remaining work offset points.
    Nov 2007
    1702
    Wait, why aren't you using the probe to set the Z height?
    How were the tool lengths set, using the Renishaw presetter or somewhere else?
    The answer to your question depends on how you did everything else.
    Greg
    Apr 2006
    235
    Quote Originally Posted by txcncman View Post
    I touch off all the tools on the table, then I touch off T01 on the top of the part. However, when I tried to run the program in simulation I get Z over travel error.
    I think that's how the manual described setting tool and work offset but I couldn't get it to work and ended up touching off all the tools on G54 and setting all work offset z value to zero and adjust the program Z values to compensate for the part height difference between the G54, G55 and G56.
    Apr 2006
    235
    Quote Originally Posted by Donkey Hotey View Post
    I am running a very basic SR-100 router with no probe and no tool changer. It's a very basic machine and even a simple manual tool change took me long while to figure out.
    May 2004
    4519
    Quote Originally Posted by JohnJW View Post
    I suspect an error in your programming causing over travel.
    Nov 2006
    490
    It depends on what you're using to qualify the tool offsets.
    In simple situations where you only have one work offset to bother with, you can oftentimes get away with setting the TLO right at your Z origin point. Here all your TLOs are negative numbers and your G54 Z is zero.
    The downside to that is you have to reset all tools when you switch to a new origin, and also if your Z origin reference on the workpiece gets machined away you have to get creative to set up new tools in case of breakage.
    The alternative to that is setting the TLO using a common point like a 1-2-3 block or something universal to the parts you're making. The TLO values from this would be negative as well, then are offset using work offset Z. For this you just need to measure the height difference between your TLO reference point and the Z origin of your program. (a couple ways to do that depending on how accurate you want it to be)
  1. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 06-04-2012, 06:31 PM
  2. Tool offset with work offset
    Last Post: 05-28-2012, 09:48 PM
  3. manually Teaching Tool length Z offset, lathe
    By 60rock in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-14-2010, 05:22 PM
  4. Is there a way to feed an offset in manually in Gcode
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2008, 04:30 AM
  5. Is it possible to work Texron both Manually and Nc controlled?
    By JMSS in forum Bridgeport / Hardinge Mills
    Last Post: 02-09-2008, 07:03 PM
