586,385 active members*
3,379 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Feedrate override vs programming a faster feedrate?
    May 2012
    124
    hey guys. So i had someone here simulate my code ...in..what software im not sure, but he said that when i override the feedrate, is when my work gets undesired inconsistencies. But, i f i dont override the feedrate, everything seems well.
    So whats the cause of this? is it, its just too fast for my machine? or is it mach3/my computer can't properly compensate for running the code faster?
    Jan 2006
    2985
    I'd equate it to you looking at the directions before you go on a trip and knowing where to turn compared to you driving blind and your wife yelling out right or left as you get to the intersection.
    Mach has to apply the feedrate override "on the fly" so it takes a lot more brain power. It is generally better to program it at the fastest speed you might run and then use the override to reduce the speed.
    Matt
    Mach3 will not run as smoothly with a high FRO value then it will with a higher feedrate and no FRO.
    The commercial routers I use at work only allow 20% higher FRO, probably for a similar reason.
  1. Rapid Traverse Feedrate Override
    By liudongxjtu in forum Fanuc
    Last Post: 08-05-2012, 12:50 PM
  2. Mach3 feedrate override
    By dynamotive in forum Mach Software (ArtSoft software)
    Last Post: 09-24-2009, 11:04 PM
  3. Feedrate override with MPG
    By foka4 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-04-2009, 10:08 PM
  4. Feedrate Override by Keyboard
    By Tazzer in forum Centroid CNC Control Products
    Last Post: 03-26-2007, 07:16 AM
  5. Feedrate Override
    By JFettig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-10-2004, 01:17 AM
