586,115 active members*
3,496 visitors online*
    Mar 2012
    Cutting HDPE Question....
    Was curious, I have never milled HDPE before and wanted to run this by someone before I started...
    I have a Probotix v90 with a Bosch Colt, I am cutting a 1/2" think piece of HDPE with a 1/8" 2 flute solid carbide bit.
    So, the questions are:
    Do I need to use higher RPMs than what I would use with wood or lower?
    Should I travel faster or slower, or just keep it the same in travel speed?
    I cut many different woods before, Birch Ply, Koa, Paduk, Maple, Pine, Wenge, and others, I have just never worked with HDPE before...
    Thanks for the help in advance.
    Depends on what you used for wood, but generally lower.
    Again, depends on what you were using.
    A single O flute is a much better choice for plastics than a 2 flute.
    Mar 2012
    I guess numbers would have helped....
    I typically run the bosch colt around 28,000 rpms to 30,2000rpms for my wood cutting with a travel speed of 15-20 inches per minute.
    For harder woods, I slow the cutter down to around 22,000 rpms. and my travel to 8 - 10 inches per minute.
    Most of the stuff I have been cutting with has been with a 1/16" 2 flute (for birch ply) or a 1/4" or 1/8" 2 flute (for solid woods to include my hard woods)
    With hard woods I have always gone lower and slower for RPMs and travel, but with HDPE, I see that it can melt easily if your not careful. Plus I would imagine it will gum up, fill the flutes and break the bit if it got too hot. That is why I am asking. I have the CAM file set to shave 1mm at a time in depth but it shouldn't sit too long in one place (except for the plunges).
    Typically with wood, I take about 1/8 off at a time.
    With a 1/4" bit, cutting hardwoods, you'd get far greater tool life at 15,000 rpm and 100ipm. For HDPE, I'd try about 20,000rpm and 125ipm.
  1. Cutting HDPE and Acetal sheets with a CO2 laser ?
    By nio101 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2012, 06:43 AM
  2. Laser cutting HDPE??
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2010, 10:13 AM
  3. HDPE cutting problem
    By leaveme in forum DIY CNC Router Table Machines
    Last Post: 11-07-2010, 03:29 PM
  4. DIY router parts: HDPE vs cutting board
    Last Post: 09-14-2010, 08:38 AM
  5. Anyone use HDPE decking lumber instead of cutting boards?
    By dbprojects in forum Commercial CNC Wood Routers
    Last Post: 05-12-2007, 03:29 PM
