586,655 active members*
4,080 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > Brown & Sharpe MicroVal Renishaw MIP Probe
    Jul 2005
    9
    We have a Brown & Sharpe MicroVal CMM with Renishaw MIP probe. We have replaced the probe maybe 4 years ago and now the replacement probe is acting up. Can you recommend a source to repair the MIP probes? The computer is a DOS based system. Can you also suggest a source for a modern replacement computer presumably with modern drivers? Thank you!
    Apr 2013
    The MIP Probe is discontinued and has been replaced with the MH20 probe. The issue I have with that is now you will have to buy modules at a cost of $900.00 ea. The modules com in low, std, med and extended force. If necessary we have 1 last MIP probe left. If you are still in need of it send a PM over.
    Regards
    Apr 2013
    The Renishaw MIP probe was discontinued and replaced with the MH20. The issue is that the MH20 requires you to buy a probe body and separate modules. The modules come in light, standard, medium and extended force. Each module will cost a bit over $900.00. If you are still in need of a MIP PM me we have one left in stock with a warranty.
    Regards
  1. Brown & Sharpe CMM screen issue.
    By NPI in forum CNC Machine Related Electronics
    Last Post: 03-14-2023, 12:11 PM
  2. Brown & Sharpe tool help.
    By praetor in forum Vertical Mill, Lathe Project Log
    Last Post: 11-02-2013, 03:12 PM
  3. Brown&Sharpe CMM PFx!
    By julioykaly in forum EDM Discussion General Topics
    Last Post: 10-12-2011, 07:01 PM
  4. WTB Feed Tube for Brown and Sharpe 00G
    By Shanghyd in forum Want To Buy...Need help!
    Last Post: 01-07-2010, 04:56 AM
