586,036 active members*
3,532 visitors online*
Page 4 of 10 23456
Results 61 to 80 of 181
  1. #61
    Re: 4'x8' RouteBot
    Is Mach4 ever going to be ready??
    Yes, someday it will.
    But I'd plan on using Mach3 when this machine is ready to start moving. Wait at least 6-12 months for Mach4, unless you want to be a beta tester.
  2. #62
    Nov 2009
    84
    Re: Gantry assembled!
    Hey I just found this thread . Whats the status of the build is it finished ? would like to see some more pics.
    I'm in the process of gathering info on the same size table.
  3. #63
    Dec 2012
    102
    Status update
    Still not finished . . . this stuff takes awhile. I have been bogged down with other projects. However, I do have a little progress to show.
    Attachment 253684
    Mock up of some z axis parts.
    Attachment 253686
    Welding the gear rack to 1/8" flat steel bar. The scrap bar is covering up the rack teeth to be sure I don't get weld spatter in the teeth. The racks come in 6 ft. lengths. They were trimmed and welded to give me a 10 ft. long gear rack with a mounting flange.
    Attachment 253690
    Rack gear welded assembly mounted to the side extrusion.
    Attachment 253688
    Test fitting the servo/gear drive. Making sure the gears line up correctly. The servo mount will get a compression spring to push the gears together.
    Attachment 253696
    Y axis rack gear location.
  4. #64
    Dec 2012
    102
    Re: Status update
    A few more pics . . .
    Attachment 253702
    Transferring hole locations to the z axis side using an expanding center punch. Then drill and tap each location.
    Attachment 253716
    Z axis mock up.
  5. #65
    Nov 2009
    84
    Re: 4'x8' RouteBot
    AWESOME!!!!!!!! Keep up the great work!!! I'm on pins and needles waiting for this thing to ROAR!!!!
  6. #66
    Nov 2009
    84
    Re: 4'x8' RouteBot
    Any more Update's on this build is it moving on it's own yet!!!!!
  7. #67
    Dec 2012
    102
    Quote Originally Posted by hacker7 View Post
    Sorry, not much to post. Work keeps getting in the way! I hope to get back on it next month.
  8. #68
    May 2011
    72
    Re: 4'x8' RouteBot
    This is a serious monster of a build! I'm a bit jealous.
  9. #69
    Nov 2009
    84
    Re: 4'x8' RouteBot
    RouteBot where do you stand on this build??????
    Just checking haven't seen any activity on the thread. Didn't want you to get discouraged on how long
    it's taking to build.
  10. #70
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Sorry for the long stretch with no progress! There was some more important things I had to deal with. So I'm back for now and moving forward again.
    Here are the latest pics of the Z axis:
    Attachment 286328
    Attachment 286326
    Attachment 286330
    Attachment 286332
  11. #71
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Installing the Z axis to the gantry.
    Attachment 286340
  12. #72
    Dec 2012
    102
    Re: 4'x8' RouteBot
    X axis servo / gearbox installed.
    Attachment 286510
    Attachment 286514
  13. #73
    Feb 2005
    829
    Re: 4'x8' RouteBot
    I love your solution to the rack and pinion drive. Very compact where it counts.
  14. #74
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Quote Originally Posted by nlancaster View Post
    Thanks, the servos with gearboxes would have been sticking way out. Hopefully, it works! You never really know how things will go until it's powered up . . .
  15. #75
    Dec 2012
    102
    Re: 4'x8' RouteBot
    When bolting the gearboxes to my servos I found one of the gearboxes to be defective. The machining in the connecting collar was not quite centered, causing binding when the bolts were tightened.
    I called Automation Technologies Inc. and told John that I had purchased the gearbox from them and is was defective. John called me today and he is shipping a new gearbox! He also upgraded a 24V power supply to a higher amp model on a recent order. I have to give a shout-out to John at Automationtechnologiesinc.com for his unbelievable customer support.
    The gearbox issue has been holding up the Z axis assembly. So I'm excited to get the new gearbox and move forward with the build.
  16. #76
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Z axis servo with brake and AMT102-V encoder installed.
  17. #77
    Nov 2009
    84
    Re: 4'x8' RouteBot
    Great Work Thanks for the Update!!!!!!!
    More,More,More!!!!!!!!!
  18. #78
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Here is a picture of my e-chain mock up. By using my air hose I can get an idea of length and connection point. Unfortunately, I'll have to remove the gantry and reverse it because the electrical box is on the other end of the router. I didn't model the e-chains and didn't think it would be an issue. Reversing the gantry will work. However, I think it will look strange having the back of the router towards the middle of the shop. Oh well . . .
    Attachment 290296
  19. #79
    Nov 2009
    84
    Re: 4'x8' RouteBot
    Did you do all of your machining of the parts for the gantry or did you have someone do it?
    Either way it's very nice work!!!!
    BTW Thanks for all pics!!!
  20. #80
    Dec 2012
    102
    Re: 4'x8' RouteBot
    I have a friend with a mill. We worked together to mill the parts. I did all the CAD work. I learned a lot, as I have no experience milling parts. Working with the mill should help me if I ever get my router done!
Page 4 of 10 23456
