586,108 active members*
3,328 visitors online*
Page 8 of 10 678910
Results 141 to 160 of 181
  1. #141
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Quote Originally Posted by RouteBot View Post
    I must be missing something. I have a NPN NC sensor as shown on the right of your picture. In the picture you have a resistor between the sensor output and +V. If I wanted to lower the voltage, it seems like I need to put the resistor between the output and -V.
    I got it. The limits work as expected!! So I thought I needed a lower voltage and I put the resistor between the ground and the output. Your diagram is correct and I was over-thinking it.
    Spindle and VFD are the next challenge . . .
  2. #142
    Dec 2012
    102
    It's alive! - 4'x8' RouteBot first motion test
    After 4 years I'm happy to see it move. Still need to get the spindle setup in Mach, but everything else is working.
    https://youtu.be/3OzesAc2l38
  3. #143
    Re: 4'x8' RouteBot
    Wow, it is looking good. Have you pushed moving the axis at good speeds?
    Tell more more about the spindle? What spindle are you using?
  4. #144
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Quote Originally Posted by arturod View Post
    I have not cranked it up yet.
    The spindle is a HSD AT/MT 1073 P/N: Y6162Y0017
    TECHNICAL SPECIFICATIONS
    Power S1/S6: 3Kw/3,60Kw
    Connection type: Collet ER25
    Rated voltage: 220V
    Rated speed: 18.000 rpm
    Max speed: 24.000rpm
    Rotation: Right
    The VFD is a Delta B series part #: VFD055B23A. It is a 7.5HP model but running on 220V so the HP rating would be reduced.
    VFD specs: http://theservicegroup.us/wp-content...5011025710.pdf
  5. #145
    Re: 4'x8' RouteBot
    Here are some recomendations:
    - Before wiring the VFD, make sure you configure the software OK, and you have the analog output on the board working ok and the relays clicking like they should.
    - You need to follow the instructions in the manual of the C32. Make sure you configure first the ESS plugin for PWM spindle speed control at 1000HZ.
    - Keep in mind that you do not need to assing relays or outputs in Mach3, just step and dir pins on the spindle, and disable the relay outputs under Ports and Pins/Spindle.
    - Keep in mind that you need to configure the VFD for control through the terminals, you need to enter into the configuration and change 2 parameters.
    - You can wire the VFD using this wiring diagram: http://cnc4pc.com/Tech_Docs/C32R4andHuanyang.pdf Yes, it is a different VFD and different revision of the board, but the terminals are the same.
    Let me know how it goes.
    Arturo Duncan
    Welcome to CNC4PC
  6. #146
    Feb 2004
    304
    Re: 4'x8' RouteBot
    Okay guys this is driving me nuts so I am going to hijack Allen's thread. About a year ago I built a small router with the same AMT encoders, and had no problem calculating the steps/in.
    Allen used the automatic calibration in Mach3 and got the positioning pretty accurate. I don't consider the move and measure method to be a valid way to set steps/rev unless you have incredibly accurate measuring instruments. I'm calculating much different numbers, and wondering if anyone can tell me what I'm doing wrong.
    For the Z: Encoder set at 2048 CPR, 20:72 pulley reduction, and 10mm lead ballscrew. So,
    8192 Pulse 72 1 Rev 25.4mm Pulse
    ---------------- * ---- * -------- * -------------- = 74,906.6 ---------
    1 Rev 20 10mm 1 Inch Inch
    Mach calculated 13,333 pulses per inch.
    X and Y use a 1" pitch diameter pinion with 10:1 gearboxes with encoders set to 1024 CPR. So,
    4096 Pulse 10 1 Rev
    ---------------- * ----- * ---------------------------- = 13,038 pulse/in
    1 Rev 1 Pi *PD (In Inches)
    Mach calculated 6,336 PPI
    He is using DG4S servo drives, and I don't see any step multiplication in the manual.
    Have I become mentally challenged in one year? What's going on?
    Kevin
  7. #147
    Re: 4'x8' RouteBot
    Kevin,
    Some things to keep in mind:
    - A quadrature sends 4 pulses per step.
    - The driver may be multipying steps. DG4S has 1X, 2X and 4X. I am not sure what you are using and if there is an option, check it.
    - Commanding a movement, then adjusting the current steps per unit in the same proportion of the error will help you correct the steps per. You can do this twice, on a short distance to get an approximation, then on a travel as long as possible to get a more accurate number. Keep in mind the larger the traveled distance the more accurate the value.
    I hope this helps.
  8. #148
    Feb 2004
    304
    Re: 4'x8' RouteBot
    Kevin,
    I hope this helps.
    Hi Arturo,
    It's Allen's machine across the country, I'm just trying to help. I already multiplied the CPR X 4 to get steps/rev in the calculations. How do you set step multiplication in the drives? That doesn't seem like it would explain things.
    Allen, have you made full travel moves and measured with a tape to check your steps/in?
    Kevin
  9. #149
    Re: 4'x8' RouteBot
    Kevin,
    In the case of the DG4S you connect using the Servoconfigurator. Which is the software for configuring and tuning the drivers.
    Arturo Duncan
    Welcome to CNC4PC
  10. #150
    35538
    Re: 4'x8' RouteBot
    Let's see some video of that thing moving around!!
  11. #151
    Dec 2014
    640
    Re: 4'x8' RouteBot
    I agree!!!
  12. #152
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Quote Originally Posted by fretman_2 View Post
    I agree!!!
    I'll get some video soon. I am going on vacation and when I get back I plan to route the dado's for the spoilboard t-track.
    Almost done with the dust collection. Got the ball joint over the table now. Also, got the dust shoe yesterday. Waiting on flex hose to show up.
    Attachment 355506
    Attachment 355508
    Using 1/4" all-thread and beam clamps to hang the ball joint.
    Attachment 355510
  13. #153
    Feb 2004
    304
    Re: 4'x8' RouteBot
    I would also like to thank kevincnc for his help over the past 4 years. He kept me moving forward. For every the curveball this thing threw at me, Kevin always had a solution!
    Glad to help, my friend. Now let's see that thing make some sawdust!
  14. #154
    Dec 2012
    102
    First cut video!
    Attachment 356716
    Dust collection finished!
    https://youtu.be/34f4b2oOf7I
    First cut video. Programed with Aspire 8.5 . . . it worked!! Note the dust collection was on and it was sucking up dust without the brush . . .
    Attachment 356718
    First cut setup
    So now I need to get this thing squared up. I cut a rectangle 60" x 97" and measured the diagonal. It's off by 1/4". Is there an offset in Mach or do I have to use limits to square the gantry?
    Also, when I ran the Aspire coded program the spindle came on at 16,000 RPM. I didn't program the spindle speed or the feed rate. Is that a default?
  15. #155
    Jan 2008
    1529
    Re: 4'x8' RouteBot
    In Aspire feed rates and spindle speed are per tool. The aspire help files are quite good.
  16. #156
    Dec 2014
    640
    Re: 4'x8' RouteBot
    Awesome!!!
  17. #157
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Quote Originally Posted by pippin88 View Post
    I just checked and I see it now. First time doing this . . . I was just happy to see it work!
  18. #158
    Re: 4'x8' RouteBot
    It is very nice. Make it go fast... Or you are not sure yet?
    Arturo Duncan
    Welcome to CNC4PC
  19. #159
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Arturo Duncan
    Welcome to CNC4PC
    I still run it with my hand on the e-stop! I'll speed it up later.
  20. #160
    Dec 2012
    102
    Re: 4'x8' RouteBot
    Since my gantry is out of square when homed to the Y2 proximity switch on the left side of the gantry, I decided to home to both Y1 and Y2 proximity switches. These proximity switches ride on each side of the gantry. The flags are mounted at each end of the Y travel.
    When I set the Y and A to home to Y2 and Y1 proximity switches it goes home, stops then starts stripping gears on the A side.
    Here are my settings:
    Attachment 356892
    Attachment 356894
    Here is a pic of the switch in the riser:
    Attachment 356898
    I can't find an example of sensors between the flags. I checked the wiring and confirmed that the home switches are lighting up the correct home lights on the diagnostic screen.
Page 8 of 10 678910
