586,069 active members*
3,471 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Countersink Speeds and Feeds, 6061, 6-flute carbide
Results 1 to 11 of 11
    Jan 2006
    179
    I am countersinking a #9 hole in 6061-T6 aluminum using a 6-flute Lakeshore Carbide "chatterless" countersink. Going until top of the hole is .411 in diameter. I know I have my feeds and speeds wrong, because I'm getting a ton of chatter, and the countersunk hole does not turn out well at all. I've tried 750 RPM at 2 in/min. What should I be running this for the perfect smooth countersink?
    Or should I abandon it altogether and go for a single flute?
    Thanks.
    Apr 2006
    3206
    It'll load up with chips because there's little room in the flutes. You have to keep the feed rate up and peck it.
    RPM is conservative in alum for a carbide, but you're ok.
    We just got thru running a 6fl carbide C'sink in 1018, same rpm, about 3.5IPM feed. Worked just fine with 3 passes on a peck cycle. We were also going pretty deep with it too.
    Nov 2012
    cnc? manual?
    I rarely use anything more than a single flute for this type of operation.
    Jan 2006
    179
    HAAS Mini Mill CNC.
    Nov 2012
    6000rpm, 10ipm sometimes too little rpm can be a bad thing...
    Apr 2006
    3206
    Quote Originally Posted by 6061-t6 View Post
    You've run a carbide 6fl at that rate?
    Guys who ran it that fast before I got there broke it. Mind you, I agree with you in theory, but in practice we had to slow things down, and this was in steel.. but we had to slow it WAY down. Part of our issue was going from a .330 hole to a 5/8 top dia. That's a pretty big bite.
    I think the real issue here is the total swept surface area x number of cutting edges, along with the lack of room for chip evacuation.
    May 2004
    4519
    Well, you found out that chatterless countersinks aren't. I usually try to use a spot drill with the appropriate angle and have my countersink finished before the hole is drilled.
    Jan 2006
    179
    Looking at some more numbers, I'm looking at trying 3400 RPM, 11 IPM, and peck it 3 times or so. How does that sound? Also, should I do something like a 0.2 second dwell at the bottom?
    Jan 2009
    123
    FWIW: HSS or Cobalt Countersinks for Alum may be a better option to avoid chatter and will likely have a better finish than Carbide. That said a constant even pressure will help reduce chatter. If the pressure is too light it causes excessive chatter, Too much feed causes it to build up with large chips fast, that also increase chatter.
    May 2004
    4519
    If you do a dwell, since you are using a 6 flute tool, calculate your dwell for the RPM to be slightly more than 1/6 of one revolution.
    Jul 2006
    525
    Quote Originally Posted by txcncman View Post
    Agreed- I've also simply had better luck with single flute countersinks for this type of application. And likely not much need for carbide here either.
  1. 1/2" 3 flute high helix and 6061 pocketing?
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 09-20-2010, 02:29 AM
  2. 2 Flute Solid Carbide Routers
    By CDTooling in forum News Announcements
    Last Post: 09-06-2010, 01:25 PM
  3. Atrax 3-Flute Carbide @ Enco
    By kevperro in forum Tormach Personal CNC Mill
    Last Post: 06-02-2009, 06:02 PM
  4. speeds and feeds
    By dek in forum RFQ Feedback
    Last Post: 05-04-2009, 08:18 PM
  5. Milling some 6061, want to move lots of metal, what feeds and speeds?
    By Loading in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2006, 07:43 AM
