586,116 active members*
3,457 visitors online*
Thread: Meldas 500
    Feb 2006
    Meldas 500
    Need Some Help On How And Were To Input Cutter Comp Using The Meldas 500 Contoller On A Cnc Mill..
    Jul 2003
    53
    Hi Pete-
    I run a VMC with a Meldas 520 controller. The way I activate cutter comp is I call out G41 Dxx in between the height plane (rapid plane) and the first 'Z' move into the part. In other words, you need to use the G41 (for climb cutting) and a D for the tool you are using. EX. G41 D07. Now in the tool length offset page there is a column that is labeled wear. In this column, the cutter comp will be entered as a negative for the appropriate tool. EX. -.005. This will add a total of .010" of cutter comp. I hope this helps you. Shane.
    Feb 2006
    no wear in machine
    i only have tool offset ,life work, and registry.. no wear
    Aug 2005
    In your tool offset page if you do not have a radius column, enter your tool radius in an empty length offset and us a G41 Hxx instead of Dxx.
    Feb 2006
    Thanks Ill Try It
