Originally Posted by
Doubleddaved
2008 VF3 Transmissions already gone. This machine is not abused or mistreated.What could cause this to happen to this VF3?
I was spotting a tube pattern in steel plates with a #6 center drill at 900rpm with about 150 spots total and roughly 15 holes spotted so far when it seemed to slip out out gear and decelerate to a stop with major noise coming from the transmission.
Service came out to inspect and agreed it was the transmission and needed to be replaced.
I'm thinking maybe 1 of the solenoids let go causing it to come out of gear while running and causing the damage.Anyone ever have this problem before? I want to find out what made this happen so not to repeat this in the future.Maybe a dedicated dryer and lube system for each machine,if this was the cause.
Haas service is going to be here this morning to replace it ($16500 with a 50% core not including labor) OUCH
Did you call for any other prices, that seems excessively high for just the tranny? I would make some quick calls------!
Mike
