586,993 active members*
3,359 visitors online*
Results 1 to 7 of 7
    Mar 2006
    101
    z axis vibration
    i've assembled most of machine, but can't get around this annoying problem
    z axis while moving downwards makes huge vibrations, while moving upwards - nothing
    so far i figured that pressing my hand against axis assembly removes vibration
    and loosening bearings on the end also helps
    x axis is assembled same as z, but it runs smoothly
    to get an idea how it sounds, check the movie film
    sta to drnda - YouTube
    Jan 2008
    853
    It is hard to tell from the vid, but are the two top jam-nuts locked up together? It looks like there might be some play there. If that is a thrust bearing just below them, it may not be under uniform load.
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
    Nov 2006
    1036
    Can't see your video (security restrictions on my computer at work) but I have some suggestions:
    1) lubicate your leadscrew (I use pneumatic tool oil)
    2) check the alignment of the leadscrew (mine made a horrible noise when misaligned)
    hope this helps
    Don
    edit: see posts #27 and #30 of my build thread: http://www.cnczone.com/forums/diy-cn...r_build-3.html
    Feb 2004
    304
    If your bearings are binding, and there is any backlash in the leadscrew nut or play in the thrust bearing assembly, it will do that.
    Aug 2011
    388
    +1 on binding plus backlash/play. If an axis has binding while a loose nut drives it up, all is well since the weight keeps it on 1 side of the backlash. But when the nut tries to lower it down, the axis can go into stick-slip mode, falling to the other side of the backlash, then stopping and binding until the nut catches up, then falling again. Bam-bam-bam vibration, similar to climb cutting on a manual mill. Grease on the leadscrew helps dampen it temporarily, but eliminating the backlash (and binding) are the best fix.
    David Malicky
    Mar 2006
    101
    thanks all for suggestions
    i think the nut is tight enough, but will check it
    that is exactly what i think is happening, dmalicky, it's like falling and catching the z assembly while moving down
    btw screw is greased, and greasing it helped a bit, but not much
    Mar 2006
    101
    solved !
    it appears that nut haven't been tight enough, now everything works much better
    thanks all for help !
  1. In 'X Axis' Having vibration
    By dspjbp in forum DNC Problems and Solutions
    Last Post: 08-09-2012, 08:31 PM
  2. Noise/Vibration on Z-Axis?
    By adt2 in forum DIY CNC Router Table Machines
    Last Post: 12-30-2011, 12:59 AM
  3. cause of Z axis vibration
    By dahui in forum Shopmaster/Shoptask
    Last Post: 08-17-2007, 03:39 AM
  4. X axis vibration
    By harvard5 in forum Servo Motors / Drives
    Last Post: 08-15-2007, 02:07 AM
  5. Vibration in X axis of lathe
    By sab in forum Uncategorised MetalWorking Machines
    Last Post: 05-19-2006, 08:57 PM
