586,069 active members*
3,484 visitors online*
Thread: File size
    Mar 2009
    291
    File size
    Is 60.5 mb to much for bobcad to open? I have a .stp file that doesnt want to open. I get bobcad not responding.
    Dec 2008
    4548
    Hi 1 2,
    The "not responding" that you may see at the top, is usually an indicator to "wait"..... You will see that if an app is crunching and you perform some other action, like "click" or a mouseover.....
    The other thing to try if you have a heavy file, is to go to the display preferences in "part" and set the surface and wireframe display way down, then also go to the view menu and turn off all the extra fancy stuff, then Merge the file in. Then you can start to bring the display back to a finer resolution.
    Mar 2009
    291
    Thanks Burr, i will give that a try.
    Mar 2009
    291
    I turned the wire frame and the shading quality way down. also turned off ortho and shading smooth. Gave it over 1 hour. This file will open in turbo cad but it takes about 10 min.
    Mar 2009
    291
    Saved it as a .stl. It will open but a few surfaces are missing. Thats not a big deal though. The only problem is all the drilled holes are coverd up. If i veiw it transparnt i can see them. I tryed extracting the edges but that didnt seem to do anything.I would like to get the edges so i can project them to a surface to get the 2d geometry.
  1. HSS file size
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-01-2012, 06:47 PM
  2. File size
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2010, 11:09 PM
  3. Machine code file size needs reducing
    By billlaws in forum Mastercam
    Last Post: 02-16-2010, 08:49 PM
  4. File size limit??? Dripfeed??
    By jsatter in forum Centroid CNC Control Products
    Last Post: 01-31-2007, 06:22 PM
