587,045 active members*
3,092 visitors online*
Results 1 to 2 of 2
    Jan 2013
    Takisawa Mach-v3 tool carosel problem
    I was having a problem with the tool changer not aligning up correctly with the Z axis. I tried moving the "cross" looking plate on top of the position switches on the back this would "clock" the carosel correctly. I guess I moved it too far and now the ATC alarm light will not go off. The only way I can get it to go off is by moving the "cross" so that the lights on the position switches go off. I can them move the carosel manually but when the position lights are on the ATC alarm light comes on and will not allow me to MO6 and call a tool. Please help as this was all functioning perfectly until I moved the "cross" looking piece in the back.
    Jan 2013
    Ok, apparently my counters are off so I need to know what parameters in the PMC control this.
  1. turret problem for takisawa tc 2
    By anantwaykole in forum Community Club House
    Last Post: 12-29-2008, 03:03 PM
  2. Fanuc 6mb tool carosel keeps spinning
    By diamond in forum Fanuc
    Last Post: 03-16-2008, 08:56 AM
  3. NEED HELP : Takisawa mac v 2e tool changer
    By srosson in forum MetalWork Discussion
    Last Post: 02-15-2008, 02:50 PM
  4. Takisawa TS-10 Indexing Problem
    By chriztopia in forum Uncategorised MetalWorking Machines
    Last Post: 09-25-2006, 02:30 PM
  5. Takisawa TS-10 Index Problem
    By chriztopia in forum CNC Machining Centers
    Last Post: 09-14-2006, 01:17 PM
