586,105 active members*
3,181 visitors online*
Results 1 to 12 of 12
    Jun 2012
    516
    Looking for Fanuc 6T-B Manual
    Hey guys, I don't post here often, just over in 'bridgeport / hardinge machines.'
    I'm looking at buying a used Takisawa TS-15 lathe. The lathe has a fanuc 6t-b controller. It's been really tough trying to locate manuals for this control even though its a fanuc.
    I also need manuals for the lathe itself. That's even more obscure I believe.
    Anyway, if anyone has 6t-b manuals, I'd be happy to buy them or a copy from you (right away!!)
    Aug 2011
    2517
    you can buy 6T manuals on ebay (etc). no PDFs are available.
    if you just need basic programming info any Fanuc manual will do with only minor differences. mostly you need to use G50 to set X/Z tool positions. Much of the rest is the same.
    Programming-wise, Fanuc 10-15 series is closest. 15B manual is available free online in pdf.
    Jun 2012
    516
    Quote Originally Posted by fordav11 View Post
    Indeed it has been tough to find this as a PDF. I've found a couple of possible manual sources. My big worry is that I have an appt. to see this machine under power (and write a check for it) on Jan. 25 (in 6 days) and I need to learn as much as possible before that.
    Dec 2008
    239
    Here are the alarm list for fanuc :
    Fanuc 6 Alarms
    Program errors or Operator's Error
    000
    Re-apply the power after the parameter has been input
    001
    TH Alarm (A character with incorrect parity was input) Correct the tape
    002
    TV Alarm (The number of characters in a block is odd). This alarm will be generated only when the TV check is effective
    003
    Data exceeding the maximum allowable number of digits was input
    004
    A numeral or the sign (-) was input without an address at the beginning of the block
    005
    The address was not followed by the appropriate data but was followed by another address of EOB code
    006
    Sign "-" input error (sign "-" was input after a address with which it can't be used. Or two "-" signs were used).
    007
    Decimal Point "." Input error (A decimal point was input after a address with which it can't be used. Or two decimal points were input).
    008
    The switch position of the tape reader was not AUTO (without reel) or REEL ON/REEL OFF (with reels).
    009
    Unusable character was input. (E).
    010
    A unusable G code was commanded. (The alarm is generated also when a G code with which the control is not equipped as an option is commanded).
    011
    Feedrate was not commanded at cutting feed or the feedrate was inadequate
    015
    The number of the commanded axes exceeded that of the allowable simultaneously controlled axis
    017
    The move commanded of the additional axis was commanded without equipping with an optional additional axis.
    018
    An additional axis was commanded with the other axis simultaneously.
    021
    The axis not included in the selected plane (by using G17, G18, G19) was commanded in circular interpolation.
    022
    In circular interpolation, radius designation was performed in the NC which is not equipped with the radius designation option.
    023
    In circular interpolation by radius designation, Zero was commanded for address R.
    030
    The tool offset number is too large for the D or H function.
    031
    In setting of offset amount by G10, The offset number following address P was excessive or it was not specified.
    032
    In setting of offset amount by G10, the offset amount was excessive.
    035
    Skip Cutting (G31) was commanded in cutter compensation mode.
    036
    G45-G48 (Tool Offset) was commanded in cutter compensation mode.
    037
    The selected (by using G17, G18 or G19) changed in cutter compensation mode.
    038
    Over cutting will occur in cutter compensation because the arc start point or end point coincides with arc center
    041
    Overcutting will occur in cutter compensation.
    044
    One of G27-G30 was commanded in canned cycle mode. An ATC cycle (M06) was commanded in canned cycle mode.
    045
    An ATC cycle (M06) was commanded for the NC which is not equipped with optional reference point return feature.
    046
    Other than P2, P3 and P4 was specified in the 2nd, 3rd and 4th reference point return commands.
    047
    G27 to G30 was commanded for and axis which does not have a reference point.
    058
    In 4-digit S code binary 12-bit/analogue output A, A command was specified exceeding the maximum or minimum number of spindle revolutions.
    059
    No program for selected work number is found (external work number select A function).
    060
    Commanded sequence number was not found in the sequence number search,
    065
    Scaling Magnification was specified as other than 1-99999.
    066
    Scaling was applied and as a result, movement value, coordinate value, circular arc radius, etc. exceed maximum programmable dimension.
    067
    G51 (scaling ON) was specified in cutter compensation mode.
    070
    The Fanuc memory area is insufficient.
    071
    The address to be searched was not found.
    072
    The number of programs to be stored exceeds 95 or 191. (191 is a option(.
    073
    The program number has already been used.
    074
    The program number is other then 1-9999
    075
    The program number or sequence number was not found at the start block of the program
    076
    The address P was commanded in the block with includes a M98 command.
    077
    The subprogram was called in triple
    078
    The sequence number which was specified by address P in the block which includes a M98 or M99 was not found
    079
    Memorized program and tape contents do not coincide
    085
    When storing data in memory by using ASR or RS232C interface, an over-run or framing error was generated
    086
    The signal level of RS232C interface was incorrect
    087
    When storing data in the memory by using the Fanuc RS232 interface, the time required to store the data is insufficient.
    090
    The reference point return cannot be performed normally because the reference point return start point is to close to the reference point or one revolution signal is not input owing to a fault in the pulse coder.
    091
    Reference point return cannot be executed normally, because of the feedrate is too low to synchronise the one revolution signal of the pulse coder with the reference counter,
    092
    The axis designated by G27 did not return to reference point.
    094
    No P type can be specified for program restart (because after program interruption, coordinate system setting or ORIGIN, etc. was executed)
    095
    No P type can be specified for program restart (because after program interruption, external work zero point offset value changed)
    096
    No P type can be specified for program restart (because after program interruption, work zero point offset value changed).
    097
    No P type can be specified for program restart (because after program interruption, no automatic operation has been executed).
    100
    The switch to set parameters is on. Push the reset button after turning off the switch.
    101
    The power was turned off while rewriting the contents of memory in the part program storage & editing operation. When this alarm is generated you must turn on the power while pushing the DELETE and RESET buttons to clear the memory.
    110
    Absolute value of data of fixed point representation exceeds the upper bound (99999999).
    111
    Exponent of data of floating point representation exceeds the upper bound.
    112
    Divisor is 0
    113
    A function that cannot be used by user macro A is used
    114
    Format error except for
    115
    Value not defined as variable number is assigned
    116
    Left side of substituted sentence is a variable of prohibited substitution
    118
    Nesting of brackets exceeds the upper limit (5).
    119
    Argument of SQRT is negative , Or argument of BCD is negative
    122
    Nesting of macro exceeds the upper limit (4)
    123
    Macro control command is uded in tape mode
    124
    DO END is not 1:1 corresponding
    125
    Format error of (formula)
    126
    Not 1 £ n £ 3 in DO n
    127
    NC command and macro command are mixed
    128
    Not 0 £n £9999 in GO TO n
    129
    Unallowable address is used in .
    130
    In external data input, greater-address data contains an error
    131
    In external alarm message, five or more alarms have occurred
    132
    In external alarm message, clear, no corresponding alarm number exsists
    133
    In external alarm message and in external operator message, smaller- address data contains an error
    170
    Programs of numbers 8000 – 8999 and 9000 – 9899 are being edited, But this alarm occurs only when parameter setting inhibits these programs to be edited.
    Error on Stroke Limit Switch
    210
    The movable part of machine touched the X Axis plus stroke limit switch
    211
    The movable part of machine touched the X Axis minus stroke limit switch
    212
    While the X Axis was moving in the plus direction, It entered into the forbidden area of the stored stroke limit 1
    213
    While the X Axis was moving in the minus direction, It entered into the forbidden area of the stored stroke limit 1
    214
    While the X Axis was moving in the plus direction, It entered into the forbidden area of the stored stroke limit 2
    215
    While the X Axis was moving in the minus direction, It entered into the forbidden area of the stored stroke limit 2
    220
    The movable part of the machine touched the Y axis plus stroke limit switch
    221
    The movable part of the machine touched the Y axis minus stroke limit switch.
    222
    While the Y axis was moving in the plus direction, it entered into the forbidden area of the stored stroke limit 1
    223
    While the Y axis was moving in the minus direction, it entered into the forbidden area of the stored stroke limit 1
    224
    While the Y axis was moving in the plus direction, it entered into the forbidden area of the stored stroke limit 2
    225
    While the Y axis was moving in the minus direction, it entered into the forbidden area of the stored stroke limit 2
    230
    The movable part of the machine touched the Z axis plus stroke limit switch
    231
    The movable part of the machine touched the Z axis minus stroke limit switch
    232
    While the Z axis was moving in the plus direction, it entered into the forbidden area of the stored stroke limit 1
    233
    While the Z axis was moving in the minus direction, it entered into the forbidden area of the stored stroke limit 1
    234
    While the Z axis was moving in the plus direction, it entered into the forbidden area of the stored stroke limit 2
    235
    While the Z axis was moving in the minus direction, it entered into the forbidden area of the stored stroke limit 2
    240
    The movable part of the machine touched the 4th axis plus stroke limit switch
    241
    The movable part of the machine touched the 4th axis minus stroke limit switch
    Error on servo system
    400
    The control received the X, Y or Z axis overload signal
    401
    The READY signal (VRDY) of the X, Y or Z axis velocity control has turned off
    402
    The control received the 4TH axis overload signal
    403
    The READY signal (VARY) of the 4TH axis velocity control has turned off
    404
    The READY signal (VARY) of the X, Y or Z axis velocity control does not turn off even though the READY signal (PRDY) of the position control has turned off
    The READY signal (VARY) of velocity control already on even though the READY signal (PRDY) of the position control is off yet at power on condition
    405
    In reference point return, reference point return is not performed in correctly by abnormality of NC control section or servo system. Perform manual reference point return again
    410
    The content of error register of the X axis is larger than the value allowed while the machine is stopped
    411
    The content of error register of the Y axis is larger than the value allowed while the machine is moving
    412
    Drift in X axis is excessive. (Exceeds 500VELO)
    413
    The content of the error register of the X axis exceeded =32767. Or the velocity command value of the DA converter is out of the range of +8191~ - 8192. Incorrect settings will cause this alarm
    414
    The resolver/inductosyn position detecting system of X axis is trouble
    415
    A feed rate exceeding 511875 detection units/sec was commanded in the X axis
    An incorrect setting of CMR causes this error
    416
    X axis pulse coder position feedback is abnormal. (Disconnection alarm)
    420
    The content of the error register of the Y axis is larger than the value allowed while the machine is stopped
    421
    The content of the error register of the Y axis is larger than the value allowed while the machine is moving
    422
    Drift in Y axis is excessive. (Exceeds 500VELO)
    423
    The content of the error register of the Y axis exceeded =32767. Or the velocity command value of the DA converter is out of the range of +8191~ - 8192. Incorrect settings will cause this alarm
    424
    The DSCG position detecting system of the Y axis is trouble
    425
    A feed rate exceeding 511875 detection units/sec was commanded in the Y axis
    426
    Y axis Fanuc pulse coder position feedback is abnormal. (Disconnection alarm)
    430
    The content of the error register of the Z axis is larger than the value allowed while the machine is stopped
    431
    The content of the error register of the Z axis is larger than the value allowed while the machine is moving
    432
    Drift in Z axis is excessive. (Exceeds 500VELO)
    433
    The content of the error register of the Z axis exceeded =32767. Or the velocity command value of the DA converter is out of the range of +8191~ - 8192. Incorrect settings will cause this alarm
    434
    The resolver/inductosyn position detecting system of Z axis is trouble
    435
    A feed rate exceeding 511875 detection units/sec was commanded in the Z axis
    436
    Z axis pulse coder position feedback is abnormal. (Disconnection alarm)
    440
    The content of the error register of the 4TH axis is larger than the value allowed while the machine is stopped
    441
    The content of the error register of the 4TH axis is larger than the value allowed while the machine is moving
    442
    Drift in 4TH axis is excessive. (Exceeds 500VELO)
    443
    The content of the error register of the 4THaxis exceeded =32767. Or the velocity command value of the DA converter is out of the range of +8191~ - 8192. Incorrect settings will cause this alarm
    444
    The resolver/inductosyn position detecting system of the 4TH axis is trouble
    425
    A feed rate exceeding 511875 detection units/sec was commanded in the 4TH axis
    426
    Additional axis pulse coder position feedback is abnormal. (Disconnection alarm)
    Connection alarm between each PCB
    600
    Data transferring error took place in the connection unit or in PC-model C
    601
    Slave relay was turned off. (Connections among unit, MDI/DPL (MDI/CRT) and master PCB are trouble. Another case change connection unit)
    602
    PC program has not yet been loaded
    603
    The correspondence between NC and PC is incorrect or interrupted. Change power sequence control PCB or master PCB
    604
    No hold is effective to PC-model B side MPU
    605
    A system error has occurred in PC-model B side MPU
    606
    RAM/ROM parity has occurred in PC-model B side MPU
    607
    Data transferring error took place in Fanuc MDI & CRT
    Overheat alarm
    700
    Overheat of the master PCB
    701
    Overheat of the PCB for 4TH axis
    702
    Overheat of DC motor for X, Y, Z axis
    703
    Overheat of DC motor for 4TH axis
    Errors on memory
    900
    Fault in bubble device. (Fault of input signal for bubble device)
    901
    Fault in bubble device. (The initial point in the bubble was not detected immediately after power on)
    902
    Fault in bubble device. (Page size error, undefined command)
    903
    Fault in bubble device. (Transfer missing, page size over)
    904
    Fault in Fanuc bubble device. (Parity error)
    905
    Fault in bubble device. (No marker)
    906
    Fault in bubble device. (Many defect loops)
    910
    RAM parity error (low byte)
    911
    RAM parity error (high byte)
    920
    System error (watch dog timer alarm)
    930
    CPU error (0, 3, 4 type interrupt generation)
    997
    ROM parity error (PC ROM)
    998
    ROM parity error (Basic ROM)
    999
    ROM pair error (No correspondence between high and low).
    Dec 2008
    239
    PARAM_INFO BIT_NO DESCRIPTN KEY
    PARAM 000 1 T/M CIRC. INTER BY RAD.
    PARAM 000 2 T/M ADD 16 OFFSETS MEMORY
    PARAM 000 4 T/M CSS B (ANOLOG OUTPUT)
    PARAM 000 5 T/M G20/G21 SWITCHING (INCH/METRIC)
    PARAM 000 6 T/M REF. POINT RET'N (2ND) 6M 0 RETURN B
    PARAM 000 7 T/M REF. POINT RET'N (1ST) 6M 0 RETURN A (MANUAL,G28
    PARAM 001 0 T/M G90,92/94 CYCLES 6M ADDITIONAL AXIS @SIM CONTROL
    PARAM 001 1 T/M AUTO TOOL COMP. 6M ADDITIONAL AXIS CONTROL
    PARAM 001 2 T/M CHAM. AND CORNER RADIUS.6M SIM. 3 AXIS CONTROL
    PARAM 001 3 T/M TOOL NOSE COMP. (RAD). 6M CUTTER COMP C
    PARAM 001 5 T/M MULTI CYCLES. 6M S2/4-DIGIT BCD
    PARAM 001 6 T/M M.P.GENERATOR
    PARAM 002 0 T/M AUTO ACCEL/DECEL. FOR FEED
    PARAM 002 1 T/M STORE STROKE LIMITS 2 AND 3
    PARAM 002 2 T/M RADIUS PROGRAMMING 6M F1 DIGIT FEED
    PARAM 002 3 T/M STORE STROKE LIMIT 1
    PARAM 002 5 T/M ** TAPE INTERFACE
    PARAM 002 6 T/M INCREMENTAL OFFSETS
    PARAM 003 1 T/M G10 OPTION 6M OFFSET DATA FROM TAPE
    PARAM 003 3 T/M ** ISO INPUT
    PARAM 003 4 T/M CLOCK DISPLAY 6M RUN HOUR DISPLAY
    PARAM 003 5 T/M RAPID TRAVERSE OVERRIDE
    PARAM 003 7 T/M PC MODEL B.
    PARAM 300 0 T MACRO A OPTION
    PARAM 300 1 T MACRO B OPTION
    PARAM 300 2 T RESTART IN PROGRAM
    PARAM 300 3 T G31 SKIP (NO MOTION)
    PARAM 300 4 T AUTO CO-ORD. SETTING.
    PARAM 300 7 T ADDN. BLOCK DELETE
    PARAM 301 1 T/M MESS DISPLAY.6M EXTERNAL DATA I/P, ALARM MSG
    PARAM 301 2 T/M 80/320M MEMORY (PART PROGRAM STORAGE) 6M 125 PGM
    PARAM 302 1 T/M VAR. LEAD THREADCUTTING 6M G60-UNIDIRECTION POSN
    PARAM 302 2 T DIRECT I/P OFFSET VALUE
    PARAM 302 3 T MIRROR IMAGE.
    PARAM 302 6 T WORK CO-ORDINATE SETTING
    PARAM 302 7 T OFFSET VALUE COUNTER I/P
    PARAM 304 2 T TOOL WEAR/GEOM.
    N0100 T/M SOME OPTIONS REQUIRE ADDN PROMS-MACRO
    N0090 T/M SOME OPTIONS REQUIRE ADDN PROMS-TOOL WEAR/GEOM.
    N0110 T/M BOARDS- MEMORY OPTIONS
    N0019 T SETTING PARAMETER
    N0020 T/M 1)PARAMETER WRITE ENABLE SWITCH "ON"
    N0021 T MODE SWITCH TO "MDI" OR ESTOP STATE
    N0015 TO CLEAR MEMORY POWER ON 'O'AND 'DELETE'KEYS
    N0022 T HAND LOAD PARAMETERS 0- 4
    N0023 T HAND LOAD PARAMETERS 300-302
    N0024 T HAND LOAD PARAMETERS 310-313
    N0025 T HAND LOAD PARAMETERS 340-341
    PARAM 000 0 6M CIRCULAR INTERPOLATION STD G02 G03
    PARAM 000 3 6M SPINDLE SPEED 12 BIT OUTPUT CSS A
    PARAM 001 4 6M CUTTER COMPENSATION B
    PARAM 001 7 6M TWO DIGIT DESIGNATORS T2/T4 TOOL FUNCTIONS
    PARAM 002 7 6M EXTERNAL DECELERATION
    PARAM 003 2 6M HELICAL INTERPOLATION
    PARAM 002 4 6M THREADING AND SYNCROUS FEED
    PARAM 003 0 6M PART PROGRAM CHECKING
    PARAM 003 6 6M STORED PITCH ERROR COMPENSATION
    PARAM 004 0 M TOOL LENGTH COMP. (G43,G44,G49)
    PARAM 004 1 M TOOL OFFSET (G45,G48)
    PARAM 004 2 M CANNED CYCLES B (G73,G74,G80-G89)
    PARAM 004 3 M CANNED CYCLES A (G80,G81,G83,G84,G85,G86,G89)
    PARAM 004 4 M CIRCULAR CUTTING
    PARAM 004 6 M SND AUXILARY FUNCTIONS B-CODE 3 DIDGITS
    PARAM 004 7 M REMOTE TYPE POSITION DISPLAY
    PARAM 005 0 M EXTERNAL WORK NO. SELECT
    PARAM 005 1 M
    PARAM 005 2 M
    PARAM 005 3 M TURRET INDEXING FUNCTIONS
    PARAM 005 4 M FT CENTRE H ATC SPECIAL ATTACHMENT
    PARAM 005 5 M FT CENTRE D/E ATS SPECIAL ATTACHMENT
    PARAM 005 6 M ROBOT INTERFACE
    PARAM 005 7 M NIBBLING CYCLE (WOODPECKER)
    N0009 CONTROL
    N0011
    N0016
    PARAM 004 5 M SCALE FUNCTIONS (MAGNESYNE-OPTISYS)
    N0026 ** CHECK SETTING DATA ISO/EIA ETC. **
    N0026 T/M
    PARAM 300 6 M 3RD/4TH REFERENCE POINT RETURN
    PARAM 300 5 M TOOL LIFE MANAGEMENT CONTROL
    PARAM 301 0 M AUTOMATIC OVERRIDE
    PARAM 302 0 M WORK COORINATE SYSTEM SETTING - G54-G59
    PARAM 000 3 SPINDLE SPEED 12 BIT OUTPUT CSS A
    PARAM 005 1 M
    PARAM 005 2 M
    N0009 CONTROL
    N0011
    N0016
    N0026 T/M
    Aug 2010
    43
    Did you find the manuals for 6T B?
    Jun 2012
    516
    yes fanuc sells a brand new un-used hardcopy for $35 + shipping. It was in pristine condition and arrived in a foam lined box. do not bother with buying it from PDF people (the 6T is not available like that anyway).
    Aug 2010
    43
    I am happy that you are sorted.
    I was looking for a manual myself, but Fanuc South Africa told me it is no more available and that they can scan one for me and that it will cost a small fortune.
    I manage to loan one from someone and got it scanned myself and saved it into a PDF file.
    The book is a bit mishandled but it is ok to use.
    Did you buy it from Fanuc in USA?
    Oct 2014
    8
    Re: Looking for Fanuc 6T-B Manual
    Hallo Mflux_Gamblej,
    can you send me a copy of fanuc 6T and fanuc 11T? Thank you very much!
    Best regards,
    Hung from Vietnam
    Apr 2006
    3206
    Quote Originally Posted by KQHung View Post
    Best regards,
    Hung from Vietnam
    .... While you're at it, can you send me some fishing poles, a couple of cases of beer, and.... oh yeah.... a bass boat?
    Oct 2014
    thank for share alarm list.
    Aug 2009
    1573
    Quote Originally Posted by fizzissist View Post
    now thats funny...
  1. Takisawa TC-2 CNC lathe, need manual book, electric book, fanuc manual
    By godzila in forum Machinery Manuals / Brochures
    Last Post: 07-20-2021, 05:43 AM
  2. Looking for a Fanuc 16-GC manual
    By fishtuna57 in forum Machinery Manuals / Brochures
    Last Post: 11-27-2013, 08:49 PM
  3. fanuc 16i-mb manual
    By ennis in forum Fanuc
    Last Post: 08-09-2012, 02:01 AM
  4. Looking for Fanuc 16 M manual
    By kbspeed in forum Fanuc
    Last Post: 12-16-2009, 06:37 PM
  5. Fanuc OTA Manual
    By thardy in forum Fanuc
    Last Post: 12-02-2006, 05:30 AM
