586,043 active members*
3,717 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Older TMate conversion to Mach3 utilizing original Microkinetics electronics
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Sep 2017
    14
    Quote Originally Posted by caddycarlo View Post
    I am working on a superdrive microkinetics to mach3 and have run into some trouble... I rewired the parallel port to more of a standard wiring the on off for the plasma cutter works great but I can not get the stepper motors to work ..they just hum and heat up ... I have tried a on board 5v power and USB cable 5v from the computer with no luck ... anyone gotten this to work? If so how?
    Got it working .... sorry for the post before
    You do need to rewire the plug on the back of the unit and it needs 5 volt signal to the driver boards from the computer .. I used a USB plug to steal the power...
  2. #22
    Mar 2009
    Re: Older TMate conversion to Mach3 utilizing original Microkinetics electronics
    Quote Originally Posted by Nutron View Post
    Hey Tom,
    Yes, I have completely eliminated the need for the dedicated OptiStep card as well as that old DOS based SuperScribe software. I am now using a newer PC running Windows XP and Mach3 alone to operate the plasma gantry and cutter. The Parallel port has replaced that antique card that connected the PC to the SuperDrive power supply/motion controller box. This weekend I will get some pictures and a schematic of what I changed posted. I am sure we can't be the only two with these older setups that would like to upgrade without spending a fortune.
    I have this setup, did you ever post the pics and schematics for this?
    thanks
  3. #23
    Nov 2005
    Quote Originally Posted by Hobart View Post
    thanks
    I also am trying to use Mach3 to be able to run my antique Torchmate plasma table.
    Did anyone ever post pictures on how they wired up to their MicroKenetics Optistep Plus driver so Mach3 will run it?
    5 volt rewire?
Page 2 of 2 12
  1. Microkinetics CNC Express SQ Conversion
    By sgore in forum Benchtop Machines
    Last Post: 10-27-2014, 01:39 PM
  2. Replies: 44
    Last Post: 11-21-2011, 05:36 PM
  3. Microkinetics 1236 cnc lathe conversion kit
    By Don Clement in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2008, 09:59 PM
  4. Older Revs. of Mach3
    By ptig185 in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2008, 09:17 AM
  5. Microkinetics and Mach3
    By skimpro in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2006, 08:16 PM
