586,103 active members*
3,342 visitors online*
Results 1 to 2 of 2
    Jan 2013
    Idea's to reduce backlash
    Decided to give a go at reducing some backlash.
    Buying a new brass nut, and will mount both and spread them apart. like a split nut but with more thread. If it reduces travel to much, I will shorten the offending one.
    Bought a new compound rest. I'll cut a half inch off it and mount that with guide pins to the end, and use set screws to adjust it to remove that back lash.
    What do you think?
    Dec 2008
    239
    Check the Mounting Bolt and Mounting jigs Of The Nuts . any Vibration also sometimes cause the Backlash in one area.
    [email protected]
  1. X2 Backlash reduction idea
    By millhead in forum Benchtop Machines
    Last Post: 04-13-2010, 01:16 AM
  2. Anti backlash nut idea
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 06-23-2007, 07:32 AM
  3. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
  4. re-load balls screw to reduce backlash?
    By cncuser1 in forum Linear and Rotary Motion
    Last Post: 10-01-2006, 02:08 AM
  5. Idea for Zero Backlash Acme nuts
    By widgitmaster in forum Linear and Rotary Motion
    Last Post: 01-16-2006, 04:11 AM
