Wow didn't expect that many pictures! Thanks.
I also should have said what do you guys think about ditching the pivoit and spring tension setup and just go with a hard mounted pinion. I know setup of the rack is going to be much more critical. What other disadvantages would one have with a hard mounted plate?
The reason I was thinking of ditching the spring tension setup is having a more consistent gear mesh with out the possibility of the gear mesh changing when you change direction (pinion riding up on the rack teeth).
