586,052 active members*
4,267 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Milacron Avenger Acramtic 850 SX Control Threading Issues
    May 2012
    We have a 1980 Milacron Avenger Lathe with a Acramatic 850 SX Control. We use Master Cam Lathe 8 and the generic Cincinnati post processor. On to our problem.
    We are trying to thread a 2-1/2"-8TPI NPT Internal thread. Mastercam is posting
    G32X....Z.....I.-.0039K.125
    According to the Cincinnati books the I(using the G32) cannot have a minus symbol or the decimal. It would also prefer the K.125 to be K8.
    We have cycled the code and it is doing some very strange things. It is cutting at an angle. However at the end of the slope it jumps up then out then back down. If we weren't cutting air the machine and part would be destroyed.
    Any thoughts or suggestions would be much appreciated.
    Oct 2008
    10
    Threading Issues
    First of all check your Tool Setup for the threading tool you are using it is most likely setup for O.D. threading that is why it pulls up and out rather than down and out from the thread.
    The K value is correct at .125 because it wants the lead distance (the amount between each thread peak) not the threads per inch, if you prefer you can have it ( K 1/8 ) in fraction form.
    You listed your Avenger as a 1980 machine; Is that a Typo? I have never heard of an Avenger that old before.
  1. Cincinnati Milacron Avenger 200s Question
    By popstorefixture in forum Cincinnati CNC
    Last Post: 11-05-2020, 10:40 PM
  2. Cincinnati Milacron Avenger 250MS
    By SINUMERIKO in forum Cincinnati CNC
    Last Post: 07-16-2012, 05:46 PM
  3. Ciccinnati Milacron 850 Sx control
    By gjenkins in forum Cincinnati CNC
    Last Post: 11-03-2008, 02:30 PM
  4. Cincinniti Milacron-arrow 750 Control Card
    By camay in forum Servo Motors / Drives
    Last Post: 05-15-2008, 12:33 AM
  5. G-code to control double threading!
    By samirnashef in forum G-Code Programing
    Last Post: 08-14-2006, 12:29 AM
