Hi guys, not sure if this is the right spot to post this question. What I'm trying to do is create a wing in CAD is a solid model and make a tool path from there. The software that I use to make the foil is Compufoil, if you know the software it is way cool. The problem exists between the two programs, I can export a DXF into CAD and see the foil and move it around but can't make a tool path because it is a raster image and not its own entity. If any one has any ideas on how I can fix this problem that would be great! Thank you for looking.
