Just hoping someone can clear up some confusion I'm having trying to select stepper motors, drives and power supplies that match.
Look at this one for example:
NEMA 23 Stepping Motor | 18.0 kg-cm | 6 Wire | 57BYGH317
1.8 Ohm 2.5A, so if I run this thing at 24V, I'll be drawing 13.3A per motor. The biggest motor driver listed on the same store can only take 6A, and it's 24 -70V. If I want to keep that motor under 2.5A, I would have to run it at 4.5V, and I don't see a lot of controllers with voltage that low. The lowest they sell is 12V. Can you see my confusion here? What do people normally do?
