Trying to wire my g0704 to my c32 board to control the spindle.
Instructions for the c32 say to power the board with a 12 or 24 volt power supply isolated from the board ground.
I used a 12v 1 amp supply from a router I had.
set the pins up in mach and when I turn the spindle on in mach to try to get a pwm signal of ten volts out of the board the max voltage I get is 1.3 volts.
turning the pot on the board will decrease and increase the voltage but 1.3 is the max.
Set the spindle velocity to the max as stated in the instructions and tried changing the accel but there is not difference.
The board does active the relay that would be used to start the spindle and I can get the spindle to move at a blazing 52 rpm.
Any ideas?
