Originally Posted by
txcncman
Upload a copy of the post processor you are using.
Tx,
please do not be offended, but
-why has everyone have to upload their post to a public forum for you & everyone else to see.
Many put hard earned hours/days/weeks into that post, just to have some piracy noob knock it off.
It is in all legal user's interest to show a little restraint, in giving away a complete post. I also find it better to guide the thread starters into doing it themselves, ( so they learn post editting in the process )
Xeno
- read the upper section of your post, tells you how to program your part while using this post
Look in your post (general output settings) for the "thread_address" setting, change it from 1 to 0 to have F output instead of the E.
(didn't have a Haas post, this is from the MplmasterX5.pst....it should be nearly identical)
Code:
# General Output Settings
force_wcs : yes$ #Force WCS output at every toolchange?
progname$ : 1 #Use uppercase for program name
css_start_rpm : yes$ #Do direct RPM spindle start prior to CSS?
css_end_rpm : yes$ #Do direct RPM spindle prior to Retract?
prog_stop : 1 #Program stop at toolchange: 0=None, 1=M01, 2 = M00
tool_info : 3 #Output tool information?
#0 = Off - Do not output any tool comments or tool table
#1 = Tool comments only
#2 = Tool table only
#3 = Tool comments and tool table
use_pitch : 0 #0 = Use feed for tapping (force Feed/Min), 1 = Use pitch for tapping (force Feed/Rev)
rigid_tap : 1 #0 = Floating tap output
#1 = Rigid tap output (Set parameter 5200 bit 0 to 1 for rigid)
#(Set M code for rigid tap in parameter 5210)
tap_feed : 1 #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places
thread_address : 1 #Thread pitch address for lathe threading, 0 = Use F, 1 = Use E
use_clamp : 1 #0 = No, 1 = Clamp
use_brake : 1 #0 = No, 1 = Brake
