586,071 active members*
4,360 visitors online*
    Nov 2010
    56
    CMOS BATTERY QUESTION
    Hello im wondering if i leave my machine off for extended periods of time im talking like 6 months will the cmos battery be dead before too long. how can i set it up to not drain? this is a centurion 6 retro fit onto a partner 4
    Sep 2010
    529
    I'm far from an expert on these controls, but I think the onboard batteries are limited in the amount of time without power. I don't think I'd trust it past a month or two. Given the Milltronics control is PC based and runs on 120V, just run an extension cord to the Tripplite power conditioner you should have in there and leave the pc portion plugged in.
    Jun 2007
    3757
    Get into the BIOS and write down ALL of the settings. It will be brain dead in 6 months.
    Oct 2008
    427
    Like with most things, the answer is "it depends" - Is this a motherboard or an SBC card? How new is the battery?, Will the machine be kept at room temp? Can you power it up periodically during the down time?
    I've had my loaner computers go for months sitting in the shelf without problems, but your experience may be different.
  1. CMOS Battery
    By Holzwurm56 in forum Bridgeport / Hardinge Mills
    Last Post: 08-18-2012, 04:37 PM
  2. Eztrac CMOS battery
    By Neil Mckillop in forum Bridgeport / Hardinge Mills
    Last Post: 05-10-2012, 02:41 PM
  3. CMOS battery
    By APinSoFla in forum Milltronics
    Last Post: 02-15-2010, 04:25 PM
  4. Fadal CMOS Battery Replacement
    By RoboVin in forum Fadal
    Last Post: 12-09-2008, 11:31 PM
  5. External cmos battery?
    By MegaMoog in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2006, 01:51 AM
